tpc wire, hooking up nos but dont know what color the wire is, need help
im put a zex kit onto my 94 b18c1, but i dont know what wire the throttle position censor wire is> can someone please help me out, thanks
its on the throttle body. not on the top thats the map sensor but on the back of it facing the firewall/driver. it has a plug with three wires in it you will have to tap the red wire on the tps.
turn the key to the on position, not sure but i believe its the red and black wire... just backprobe the wire with the positive end and hook the negative end of the voltmeter to a ground. at idle it should read ~.5volts and at wot it should read ~4.5volts.
the 3 wires are ground,power,and signal to ecu.
hope this helps.
[Modified by flex97itr, 6:46 AM 1/28/2002]
hope this helps.
1badITR
Jul 9, 2005 11:24 AM
dpw41285
Nov 12, 2004 07:25 AM
