Has anyone adjusted their steering rack?
Old Apr 4, 2005 | 09:30 PM
*Boostwerks*'s Avatar
Default Has anyone adjusted their steering rack?
Mine feels like there is some play, or looseness in the rack. I'm just wondering if anyone has adjusted it?
Old Apr 4, 2005 | 09:38 PM
Rywire's Avatar
Default Re: Has anyone adjusted their steering rack? (Bryson)
Yes, i messed with the adjustment. I helped a little
Old Apr 4, 2005 | 09:53 PM
Default Re: Has anyone adjusted their steering rack? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Yes, i messed with the adjustment. I helped a little</TD></TR></TABLE>
Where is the adjustment, and How do I go about doing it? My F'in book doesn't say anything about adjustment...just removal and installation.
Old Apr 4, 2005 | 10:13 PM
Rywire's Avatar
Its that jamb nut, loosen the outside, and adjust the center bolt
Old Apr 4, 2005 | 10:26 PM
SilentWrath's Avatar
where exactly is the jamb nut located, on the steering rack itself on the subframe, or inside the car where it meets the steering linkage to the steering column???
Old Apr 4, 2005 | 11:07 PM
DocSean's Avatar
I'd like to know also!
Old Apr 4, 2005 | 11:13 PM
imported2nv's Avatar
it's on the left rear side of the rack use a set of channel locks and a 14mm wrenchleft for the cap nut
and right to tight the steering and left to loose the rack do a little at a time not much adjusting needed
DREW410
Suspension & Brakes
Oct 19, 2017 10:06 AM
jr_istheman
Apr 30, 2009 10:01 AM
an2ny888
May 27, 2005 05:06 AM
teg92
Jul 31, 2004 10:20 PM
