Fuel pressure
Old Apr 4, 2005 | 08:35 PM
b18c1civic95's Avatar
Default Fuel pressure...92 psi
i read through about 50 fuel pressure posts and i know that everyone
sees a jump in fuel pressure with the install of a wahlbro 255.
but i fixed that when i had my stock fpr on by drilling a small hole,
then i got an aem fpr and installed it. got it down to about 56 or so with the screw all the way out.
well know all of a sudden when i started mycar up one day the fuel pressure was at 76. so i put the stock drilled out fpr the pressure was 82!! Some of these posts people say that you might have a blocked return line but i can't see 50 people having a blocked return line.
I checked anywayz and it's clear. Not bent or dented in. Does the walhbro 255 have a return on the pump itself. i know its not called a return but you know, a pressure return incase the flow line gets backed up it'll loop right at the pump and maybe it went bad. anywayz i guess i try my stock pump?
Modified by b18c1civic95 at 10:37 PM 4/9/2005
Modified by b18c1civic95 at 9:27 PM 4/11/2005
Old Apr 7, 2005 | 05:49 PM
Default Re: Fuel pressure (b18c1civic95)
bump
Old Apr 7, 2005 | 05:51 PM
jackstands's Avatar
That's what the FPR is for. Turn down the pressure.
Old Apr 9, 2005 | 09:24 PM
Default Re: Fuel pressure (jackstands)
lol good info ! wTF? anywayz so i took the regulator off and ran it into a bucket and the fuel pressure was 92!!!!!!!! WTF. Is the 2 way valve the tank vent?i looked at a diagram and that runs back to the evap canister. i unplugged that and it was still high so i guess its not a plugged up can?! i've blown through the return line. but like i said with the return line going straight into a bucket it reads 92.
Modified by b18c1civic95 at 10:35 PM 4/9/2005
Modified by b18c1civic95 at 9:30 PM 4/11/2005
Old Apr 10, 2005 | 04:48 PM
anyone?......anyone ever had to replace there 2-way valve?
Modified by b18c1civic95 at 7:54 PM 4/11/2005
Old Apr 11, 2005 | 07:01 PM
bump
Old Apr 18, 2005 | 06:34 PM
CivicHatchback14's Avatar
bump. Did you put that other FPR on yet?
Old Apr 24, 2005 | 07:34 PM
Default Re: Fuel pressure (CivicHatchback14)
yeah and it works with the stock fuel pump but then i throw my wahlbro back on there and it goes back to 80psi and when i adjust it down it stalls around 70psi.?????????????
boosted 95 coupe
Sep 12, 2008 04:43 AM
jaretron3030
Sep 3, 2008 08:11 PM
o'malley_808
Aug 22, 2006 01:35 PM
hybrid_vtec
Aug 5, 2004 10:03 AM
SOFLSOL
Feb 24, 2004 03:42 PM
