fields vtec controller wiring ?
Old Apr 4, 2005 | 06:50 PM
dpine's Avatar
Default fields vtec controller wiring ?
I looked here. http://asia.vtec.net/beystock/....html
My question is you electro-tap 2 wires (ignitor signal and rpm signal) What about the other 4 wires? Do I cut them and splice the harness side to 1 wire on the fields and splice the ecu side to the other side of the fields controller. Example (vtec signal) blue wire towards engine harness side and the yellow wire towards the ecu side?
thanks
Old Apr 8, 2005 | 07:11 AM
EnjoyTheRideDC2's Avatar
Default Re: fields vtec controller wiring ? (dpine)
Yes, Cut the wire in half and connect the corresponding wire from the fields unit to each end. I suggest soldering the wires if you can. If not, make sure your crimps are tight.
kornkid21792
Feb 10, 2010 06:48 PM
90Rexx
Mar 26, 2009 10:36 PM
Mr Hammond
Oct 20, 2003 10:01 AM
lightningd
Apr 4, 2003 01:30 PM
