JDM CRX power window help
check the 90-91 civic sedan manuel. you can download them online. the wire colors will most likely even be the same as the JDM CRX. thank you honda for keeping things simple.
http://www.norcalcrx.com/library/
vtec suplement wiring diagrams
But i just used 2 SPDT switches and ran them to reverse polarity.
That **** is so hot...I love the placements on the e-brake....with some regular Kragen Relays......
As far as i know you'll have to add one amp...for the motor.....Check....integra.oricon.net....or something liek that....that guy has everything from his DA....but it converts fairly nicely to the states crx stuff....wiring wise anyway.
its so simple!!! forget colors, think "functions"
You want to understand how they work first, not just touch wires together at random.
First test would be the motor test, you take positive and negative directly from the battery and touch it for a second one way, (goes up or down) then the other way (goes up or down) by knowing which way the window moves on those 2 wires with which polarity, you now know which way they go.
Pay "Nikitad" to do it for you. He's local. PM him.
http://www.the12volt.com UNDERSTAND WIRING - checkout the relay wiring guides.
cor4ey
Jan 13, 2009 06:51 AM
