stock gsr rods at 9k
Old Apr 4, 2005 | 05:44 PM
redlseg's Avatar
Default stock gsr rods at 9k rpm
will stock gsr rods withstand the high rpm with 11:5 compression?
Old Apr 4, 2005 | 06:59 PM
redlseg's Avatar
Default Re: stock gsr rods at 9k rpm (95eg6allmotor)
up
Old Apr 4, 2005 | 08:30 PM
Hybrid96EK's Avatar
I've been running mine up to 8,800rpms quite often for 7k miles now with no issues. I have the bottom end balanced however.
Old Apr 4, 2005 | 08:37 PM
2k.civic.si's Avatar
Default Re: stock gsr rods at 9k rpm (Hybrid93Eg)
mine have seen 11k now and again....they are shot peened micropolished and have arp bolts in them though....and the entire rotating assembly was balanced including clutch/flywheel....but they havnt broke yet...i usually shift at 8800to9000 though....
Old Apr 4, 2005 | 09:42 PM
Kendall's Avatar
Basically if you have them balanced well enough you shouldn't have a problem. Running ARP rodbolts is definately a wise idea regardless of how high you're revving.
Old Apr 5, 2005 | 09:45 PM
dt4life's Avatar
Default Re: (Kendall)
Where can you purchase ARP rod bolts?
Old Apr 6, 2005 | 03:17 PM
ALLMOTOR18's Avatar
Mine has 50k miles with 9000 rpm pulls every chance i could get.. No problems here..
Old Apr 7, 2005 | 06:37 AM
chameleon's Avatar
Default Re: (wannaTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Where can you purchase ARP rod bolts?</TD></TR></TABLE>
http://www.nolimitmotorsport.com
its good to have the bottom end balanced and shot peening the rods definitely will help but a definite insurance would be swapping to arp bolts
Old Apr 7, 2005 | 09:08 PM
Evo-man@20psi's Avatar
Damn thats a lot of rpm
Old Apr 8, 2005 | 12:29 AM
dt4life's Avatar
Default Re: (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">
its good to have the bottom end balanced and shot peening the rods definitely will help but a definite insurance would be swapping to arp bolts </TD></TR></TABLE>
awesome thanks bro
Old Apr 13, 2005 | 01:26 PM
Joseph Davis's Avatar
They occaisionally come apart on compression downshifting.
Old Apr 13, 2005 | 01:34 PM
Casey's Avatar
Default Re: stock gsr rods at 9k rpm (J. Davis)
ive done 9k plenty of times wiht stock gsr rods, but like joseph said, compression downshifting is probably not a good idea.
Old Apr 13, 2005 | 09:35 PM
Default Re: stock gsr rods at 9k rpm (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">ive done 9k plenty of times wiht stock gsr rods, but like joseph said, compression downshifting is probably not a good idea. </TD></TR></TABLE>
Brad Z, son, not Joey on that one. I'm tuenarboy trash, not an engine builder, to offer definitive explainations on engine failure. Maybe one day, though, eh?
Just the old eidetic memory kicking in...
... which reminds me, nothing wrong with stock rod bolts (unless reused, like any torque to yield fastener) in a Honda. The rod fails in other areas.
tempsohc
13
Jun 25, 2011 02:24 PM
blackccoupe
Sep 26, 2009 01:24 PM
Lsweez
Nov 28, 2007 04:03 PM
Power Rev Racing
Sep 22, 2004 07:34 PM
EfC5J1
Mar 4, 2004 02:11 AM
