No fuel pump power after MPFI swap
Old Apr 4, 2005 | 05:00 PM
xci_ed6's Avatar
Default No fuel pump power after MPFI swap
Any idea's what i did wrong?
Main relay is good, main relay harness tests good according to FSM. ECM is good. I swapped computers & relay's with my spare car just to check.
Basically All I've found is that the green/black wire on the ECU (pin's A12 & A14) don't get power on the dead car, but do on the good car. Also the fuses all check out good on the dead car.
-Dustin
Old Apr 4, 2005 | 05:08 PM
xci_ed6's Avatar
Default Re: No fuel pump power after MPFI swap (krustindumm)
reviewing my wiring diagram it seems the yel/black wire at A13/A15 should also get power but does not, I didn't pick up any voltage there on the other car though.
this is really confusing because according to the diagram of the main relay, as soon as IGN is on the relay closes connecting the yel/wht wire to the yel/blk wire, and it should get power, but it doesn't.
Old Apr 4, 2005 | 06:18 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Make sure this fuse is good:
Old Apr 4, 2005 | 06:20 PM
xci_ed6's Avatar
ok i was wrong, there was a blown fuse, grn/blk and yel/blk both get power, fuel pump still doesnt
Old Apr 4, 2005 | 06:24 PM
xci_ed6's Avatar
i just realized grn/blk should be getting a ground, but i think it was getting 12V. So BRB
Old Apr 4, 2005 | 09:09 PM
doublethink's Avatar
if your fuses are ok keep double checking stuff against what the helms says, its probably a crossed wire.
Old Apr 4, 2005 | 10:14 PM
NikoZai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">i just realized grn/blk should be getting a ground, but i think it was getting 12V. So BRB</TD></TR></TABLE>
I'm positive you just found your problem.
get it.. positive... LOL
Old Apr 5, 2005 | 07:00 AM
xci_ed6's Avatar
Default Re: No fuel pump power after MPFI swap (NikoZai)
that is my problem but why idk
the helms does not include test procedures for this part of the harness
time to unhook my added wiring i suppose.
Old Apr 8, 2005 | 02:48 PM
xci_ed6's Avatar
also no injector pulse, looks like its time to start over
Ri5e
Jun 4, 2024 08:52 AM
Jamesb223
Jan 21, 2018 08:01 PM
milanoitr
54
Feb 28, 2012 09:07 PM
redline1320
Apr 27, 2010 06:55 PM
jaerikd
Oct 6, 2009 08:10 PM
