should i get one ?
Old Apr 4, 2005 | 03:41 PM
red_ek_hatch's Avatar
Default should i get one ?
im running a itr ecu with my b16 swap . currently my vtec kicks in at 5500 rpm's . is it worth getting a apexi VAFC ? would i be able to adjust my vtec to kick in at a lower rpm with the VAFC ?
Old Apr 4, 2005 | 04:58 PM
.1type.'s Avatar
Default Re: should i get one ? (red_ek_hatch)
yes, you can vtec kick in at what ever rpm you want.
Old Apr 4, 2005 | 05:13 PM
Default Re: should i get one ? (1type)
some one is selling me a vfac for $180 is that a good price or can i get it cheaper than that some where else ?
Old Apr 4, 2005 | 05:18 PM
DelSolDon's Avatar
i hear about used one's around here for $150 all day long. you don't want to set your vtec too low either. if you just want to adjust the point at which your vtec "kicks in", get a vtec controller. i know autotechnics sells one for like $100 maybe. i dunno, never really checked into changing my vtec crossover point. do some research if not before you buy, but at least before you go lowering the crossover point.
Old Apr 4, 2005 | 05:28 PM
Default Re: should i get one ? (DelSolDon)
well actually im goin to get my motor tuned in about a month . im goin to get get my FPR , adjustable cam gears and the VAFC tuned at the same time . im just looking to get better performance while everything running right . the guy is selling it for $180 but im goin to offer him $150 . but yeah not reallyjust looking to adjust the vtec but to adjust everything else . currently my vtec kicks in at about 5500 rpm's . so im not sure how much lower can that get . im currently runing I/H/E , intake manifold , test pipe ,
cam gears , fuel pressure regulator , along with the ITR ecu . deffently worth getting the VAFC ?
2lobes1engine
15
Apr 12, 2004 10:33 AM
civictypenos
Aug 25, 2003 05:29 PM
civictuned
Aug 1, 2003 04:36 PM
Wet Nudl
Feb 25, 2002 01:46 PM
