wheelhop
Old Apr 4, 2005 | 03:21 PM
zexifiedlude's Avatar
Default wheelhop
aight i dont know y but i get evil wheelhop, i rev the car till like 2k and feather out the clutch and all it does is bounce? is that my motor mounts? or whats up? thanks fellas!
Old Apr 4, 2005 | 03:26 PM
md23vtec's Avatar
Default Re: wheelhop (zexifiedlude)
Could be motor mounts, tires compound, driver, clutch, suspension setup to many things to list.
Old Apr 4, 2005 | 04:34 PM
jackstands's Avatar
Depending on how old your car is, it could also be your bushings, esp. your radius rod bushing.
Old Apr 4, 2005 | 04:37 PM
4.6LJeepXJ's Avatar
Default Re: wheelhop (jackstands)
Could be of Driver/Cluth/Mounts/Throwout Bearing/Abuse
Old Apr 4, 2005 | 04:56 PM
97Preludeguy's Avatar
Default Re: wheelhop (4.6LJeepXJ)
Energy Suspension makes polyurethane motor mount inserts that make a work of difference in terms of wheel hop.
Old Apr 4, 2005 | 05:19 PM
Nikoli's Avatar
Default Re: wheelhop (97Preludeguy)
first off thats what stock cars do best
you need the es motor mounts and a torque damper. i just installed an NRG damper on my car with the es front mount in and i have NO wheel hop . yup thats right NONE!!11!! thats also with 350hp
Old Apr 4, 2005 | 05:22 PM
Hawkze_2.3's Avatar
Default Re: wheelhop (Deckedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">you need the es motor mounts and a torque damper. i just installed an NRG damper on my car with the es front mount in and i have NO wheel hop. yup thats right NONE!!11!! thats also with 350hp </TD></TR></TABLE>
Nice ... Are you using the one made for an Accord?? How did you mount it?
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
teddy_dc2
May 2, 2006 10:32 PM
dtrtw
May 31, 2005 05:59 PM
dtrtw
May 31, 2005 05:07 PM
AllMotorITR
Nov 22, 2001 04:37 PM
