Timing Belt Honda civic 97, Any experiences ?
Old Apr 4, 2005 | 02:58 PM
hondaowner's Avatar
Default Timing Belt Honda civic 97, Any experiences ?
Guys,
Please do share your experiences on changing the Timing Belt on Honda civic 97 LX. I am planning on DIY task.
How complex is this job ?
Based on your experiences i might decide whether to do it myself or go to a shop.
My car has 100k miles on it now.
My questions are :
1. What special tools are needed ?
2. How long does it take ?
3. Any good resources that might be helpful. I have hynes manual and it dosen't seem all that good.
4. Is the Water pump necessary to change.
5. Dealer wants $595 for the timing belt change includes water pump cost as well. I think i can do it.
All experiences are appreciated.
HondaOwner.
Old Apr 4, 2005 | 03:11 PM
Tenshi's Avatar
Default Re: Timing Belt Honda civic 97, Any experiences ? (hondaowner)
you'll probably want a good chain wrench or strap wrench to take of the crankshaft pulley. Other than that, just a good set of sockets.
You can probably do it over a couple of hours.
It's not really that complicated. either haynes or chilton's manual should be sufficient.
It isn't necessary, but it's a good idea to do so. You might as well do it while you have the car jacked up.
Not really a quesiton, personally, I wouldn't pay that much.
Old Apr 4, 2005 | 03:42 PM
WildPig's Avatar
Default Re: Timing Belt Honda civic 97, Any experiences ? (Tenshi)
Another note: if you have access to an impact wrench, that makes the crank pulley job like 100 times easier.
I wouldn't pay 600 for that either, if you decide not to do it then take it to another garage, it should be about half that.
Old Apr 4, 2005 | 04:26 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Timing Belt Honda civic 97, Any experiences ? (WildPig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig &raquo;</TD></TR><TR><TD CLASS="quote">Another note: if you have access to an impact wrench, that makes the crank pulley job like 100 times easier.
I wouldn't pay 600 for that either, if you decide not to do it then take it to another garage, it should be about half that.</TD></TR></TABLE>
300 bucks for timing belt, water pump, valve cover gasket, cam seal, Honda coolant, AND installation with all Honda Genuine parts!??? ha, nice try. The parts alone cost about 150-200, depending on the deal.
Do not use a strap wrench or a chain, use the correct tools....either a crank pulley tool, or stop the flywheel with a pry bar.
Old Apr 4, 2005 | 05:53 PM
hondaowner's Avatar
Default Re: Timing Belt Honda civic 97, Any experiences ? (Evs-One)
guys,
Thanks yaa all for the advices.
Well one ? (may be stupid one, pls excuse. after all it is a learning experience)
The Hynes manual dosen't talk about draining the coolant and some of the DIY/FAQ's etc on this site talks about draining.
Can any one explain ?
I am still educating myself to make sure that i can do it all.
Thanks and appreciate for all expert responses
Old Apr 4, 2005 | 06:43 PM
hondalowlow's Avatar
its just like any other d sires. 12mm 10mm and 17mm take your time...
maflover2
Feb 27, 2008 07:40 PM
imadigitalgod
13
Jun 13, 2006 02:10 PM
hondaowner
Apr 6, 2005 09:32 AM
shanemane81
Aug 17, 2004 01:03 PM
Civic-Ex-98
Jan 11, 2004 03:04 PM
