Put new wheels on, and now unusual sound?
Old Apr 4, 2005 | 02:53 PM
BrandonClaps's Avatar
New User
Default Put new wheels on, and now unusual sound?
I put my summer rims/tires on and now i have this unsual sound, the sound changes with speed like its the tire, but i thought it might have been the wheel bearing. So i put my old wheel back on the front driver side to see if it went away, and it did.
I brought the summer rim/tire to local tire place to have them check it and balance it. They re balanced it and i tried it again, and still the same problem.
I checked the bearing and there is like no play at all. I remember last year when i had the rims on that the sound was coming from the back and now that i rotated them to the front its starting up there.. What can it be if its balancing out fine?
Old Apr 4, 2005 | 03:21 PM
Misfit's Avatar
Default Re: Put new wheels on, and now unusual sound? (BrandonClaps)
check for nails or for something inside of the wheel and tire itself... where did you get them mounted and balanced? They might be able to help you out as well.
Misfit's Avatar
Default Re: Put new wheels on, and now unusual sound? (Misfit)
are you using hubcentric rings? could be that too.. if they don't fit snug that is..
Old Apr 4, 2005 | 03:23 PM
New User
yea i went through the whole tire, holds air fine, nothing noticible in the tread. the tire shop i brought it back to is the one that mounted it and balanced it. They just rebalanced it, and still problems
i am using hub centric rings, but it seems to seat snuggly up against the hub
Old Apr 4, 2005 | 03:25 PM
Misfit's Avatar
Default Re: (BrandonClaps)
are your wheels rubbing your tire wells? what size are they? brand... could be an offset issue as well.
Old Apr 4, 2005 | 03:29 PM
New User
Default Re: (Misfit)
they are 17"...this is the 3rd year of me running them...problem didn't happen for the first 2 years well end of last year just before i took them off.
Old Apr 4, 2005 | 04:07 PM
Bbasso's Avatar
bend your heatshields ?
Old Apr 4, 2005 | 04:28 PM
New User
dust sheilds you mean?
whereever i put this one wheel, the noise goes to that corner
Old Apr 4, 2005 | 05:02 PM
Mythais's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">dust sheilds you mean?
whereever i put this one wheel, the noise goes to that corner</TD></TR></TABLE>
That's pretty messed up right there.
Old Apr 4, 2005 | 05:06 PM
New User
Default Re: (Evil Lip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Lip &raquo;</TD></TR><TR><TD CLASS="quote">That's pretty messed up right there.</TD></TR></TABLE>
your tellin me, and they balanced the wheel and it does the same thing.... I'm clueless as to what to try now
Old Apr 4, 2005 | 05:11 PM
Mythais's Avatar
your tellin me, and they balanced the wheel and it does the same thing.... I'm clueless as to what to try now</TD></TR></TABLE>
Well, it sorta has to be the tire. The wheel, unless its cracked, can't make noises like that.
Since the tires are old, I suppose it's time to bite the bullet and replace them. I mean, if the cords are separating and making noise like that, you don't want to be riding around very long like that... *shrug*
Old Apr 4, 2005 | 05:36 PM
migs's Avatar
Your tires are feathered
Some tires are more succeptible of getting feathered i.e. Kuhmo MX, Falken ZE512, Bridgestone S03, Dunlop SPA2.
Feathering is caused by several things but mostly alignment. You will not be able to get rid of the sound UNLESS (even maybe) you flip the tires, meaning swap sides of the tires.
Old Apr 4, 2005 | 06:14 PM
New User
the tires are avs-es100's they have no more then 5k miles on them... and its only that 1 tire...still feathered?
Old Apr 4, 2005 | 06:19 PM
Misfit's Avatar
did you get a warranty with your tires? if so.. trade it in..
Just get a new set of tires or a new tire.
Old Apr 4, 2005 | 06:24 PM
Chris F's Avatar
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Your tires are feathered
I had to google it, I've never heard of that.
Sounds like a good solid burnout could fix it?
Feathered Toe Angle:
This type of tire wear is typically caused by misalignment and can easily be felt by running your hand along the tread.
Old Apr 4, 2005 | 06:27 PM
baonest's Avatar
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
. </TD></TR></TABLE>
hahaha
Old Apr 4, 2005 | 06:34 PM
New User
lol i have been spinning them on the wet roads like crazy thinking that would fix it, so far nothing
i think tomorrow i'm gonna go feel up my tires
i wonder what kind of warranty is on the yoko's
Old Apr 4, 2005 | 07:25 PM
migs's Avatar
It doesnt matter how many miles your vehicle has. I also forgot to mention ES100's are also a bad tire to feather. The bigger a tread block, the higher chance to feather.
Rotate that tire to the back and it should move the sound to where you can hear it the least.
Old Apr 4, 2005 | 10:03 PM
mugenracer's Avatar
Put that rim on the back of the car and see if you get the same noise with the original rear rim on the front, if you dont then its definitely the tyre and not the rim or dust shields or whatever
Old Apr 5, 2005 | 02:52 AM
uNF$@#!'s Avatar
Default Re: (migs)
actually my azenis right now sound like 4 bad wheel bearings...so much that i couldnt tell if i actually had a bad wheel bearing.
i took off my azenis this winter for winter tires and wow, were they quiet!
this past weekend...back to the loud noisy azenis
Old Apr 6, 2005 | 10:38 AM
Lip's Avatar
Lip
fyi.
Evil lip does not = Lip
Old Apr 10, 2005 | 05:57 PM
hondaguyexsi's Avatar
Default Re: (Lip)
if its a humming noise its a tire hum whisk the tire was not molded correctly or could have a broken belt
Old Apr 10, 2005 | 11:15 PM
markpaco's Avatar
I would have guessed wheel weights hitting the calipers but you are running larger wheels.
Old Apr 11, 2005 | 03:19 AM
kim_2_da_chee's Avatar
Default Re: (markpaco)
What does a "feathered tire" sound like when driving?
Maybe something grew inside your tire and it's bouncing around?
4everVtec
Mar 19, 2017 09:11 AM
oneano
Honda Civic (2001 - 2005)
May 22, 2011 02:21 PM
Stykz
Oct 16, 2008 09:01 PM
rollercosta123
Sep 3, 2006 04:23 PM
mikeunreal2
Mar 1, 2006 02:21 PM
