installing front axles
Old Apr 4, 2005 | 02:43 PM
fuzzball's Avatar
Default installing front axles
I have a 90 accord that I can't get the new or old axles back in. They stop about an inch short of going all the way into the trans. I've tapped on them with a mallot and the don't move at all. What's the trick?
Old Apr 4, 2005 | 03:29 PM
iam7head's Avatar
Default Re: installing front axles (fuzzball)
put most of the axle in the trans first, put the other end in the hub, then now you just need to put it in, most of the people doing their honda axle at home i know done it like this.
just make sure you have all the seal and spine lined up good or you'll wasting time.
you know your axle is in when you hear the magic CLICK
Old Apr 4, 2005 | 07:28 PM
Schmitey's Avatar
Default Re: installing front axles (iam7head)
yeah they're tricky man
I ended up having my dad hold up the axle and just kicking the end of it. A rubber mallet is your friend, and don't be scared if its stiff. I've never seen anyone slide in an axle with their bare hands. Did you lube it up or anything?
Whatever you do DO NOT BEND THE THREADS on the end of your brand new axle. I recommend threading the nut on just in case, that way you can bend the threads back if need be. My buddy did that and totally threw away $200.
Old Apr 4, 2005 | 08:50 PM
raceACCORDingly's Avatar
this may sound dumb but have you tried putting the other end in. dont ask me how i know. haha
Old Apr 4, 2005 | 09:03 PM
CD7power's Avatar
Default Re: (raceACCORDingly)
just make sure the the axle is aligned correctly like stated above. then give it a good shove, it'll get in there eventually. i would also recommend a rubber mallet.
Old Apr 4, 2005 | 11:53 PM
SpeedFreak77's Avatar
Default Re: (CD7power)
I have never needed a rubber mallet, if it doesn't go in after trying to slide it in try taking it out and turning it a bit and trying again. Also put a little wd-40 on the end and it will slide into the disc a lot easier.
Old Apr 5, 2005 | 04:47 AM
Monkey Fing a Coconut's Avatar
Default Re: (SpeedFreak77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 &raquo;</TD></TR><TR><TD CLASS="quote">I have never needed a rubber mallet, if it doesn't go in after trying to slide it in try taking it out and turning it a bit and trying again. Also put a little wd-40 on the end and it will slide into the disc a lot easier.</TD></TR></TABLE>
wouldnt wd-40 break down the grease that should be applied to the end of it??? i would just make sure its lubed up good and use the rubber mallet
Old Apr 5, 2005 | 05:48 AM
dirtracer's Avatar
all these ideas are good I've changed engines a few times and run into the same problem. what I did was use a 2x4 and a wedge or shorter piece on the driver. side and just pry on it till it goes in; same on the pass. side I also have the front end off the floor it seems to make them go in easier. Pry on cv joint;;they won't break goodluck
Old Apr 5, 2005 | 10:43 AM
supercreed2002's Avatar
Default Re: installing front axles (Schmitey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey &raquo;</TD></TR><TR><TD CLASS="quote">...I've never seen anyone slide in an axle with their bare hands.</TD></TR></TABLE>
I have on my 1992 Accord EX... line it up and press hard. You'll get it in!
Caleb
angrysmileyface
Oct 11, 2015 03:57 PM
chris89
Transmission & Drivetrain
Aug 28, 2015 09:51 PM
Dave_Dc2
Sep 23, 2009 11:34 AM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
FormulaGSR
Oct 5, 2004 04:34 PM
