b16 high idle
i have a b16a 93 civic hb and my idle is to high and sometimes the idle moves up and down from 1,400 to 2,500 rpms i triggered the ecu and i got codes 36( traction control..found on jdm ecu's) and code 41 (primary oxygen sensor heater) what is that primary oxygen sensor ?,...........does n e body have a pic? i already checked for vacumm leaks but there isnt n e how can i fixe my idle problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Above6K »</TD></TR><TR><TD CLASS="quote">It means check your O2 sensor. Down there screwed into your B-Pipe on your exhaust. Take it out and borrow a friends if you can to check it real quick.
it should look something like the pic above. if the o2 sensor is replaced and still doesn't help, try adjusting the FITV, usually beneath the throttle body. My b16a would cold start at 2k, but after fixing it, it's at 1.5k.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1TwistedEG »</TD></TR><TR><TD CLASS="quote">check intake air temperature sensor..mines idling up at 2k and wont go and changed that..fixed it</TD></TR></TABLE>
Where is the located, mine idles at 1.5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlosd68 »</TD></TR><TR><TD CLASS="quote">my idle goes up and down from 1500 to 2500 .it used to do this only sometimes but now it does it all the time</TD></TR></TABLE>
FITV.... here: https://honda-tech.com/zerothread?id=699787
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kaneo »</TD></TR><TR><TD CLASS="quote">
Where is the located, mine idles at 1.5.</TD></TR></TABLE>
What motor? Its on the IM.
