Adjusting idle on B18c1
Old Apr 4, 2005 | 02:19 PM
X2BOARD's Avatar
Default Adjusting idle on B18c1
I'm trying to adjust my idle, but the thing just won't budge !
The first time I tried to adjust it with a flat tip screwdriver, a chip of some material seemed to split off the top of the screwhead and I don't know what the ^%( it was. Is there some sort of wax topper over the screw from factory ?
Either way, I don't want to force the screw, but it doesn't seem to move easily at all... is this as straight forward as it should be or is there something I'm missing ?
Old Apr 4, 2005 | 02:32 PM
escape2me's Avatar
Default Re: Adjusting idle on B18c1 (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to adjust my idle, but the thing just won't budge !
</TD></TR></TABLE>bump i would also like to know... BTW what is the point of adjusting the idle?
Old Apr 4, 2005 | 02:40 PM
X2BOARD's Avatar
After swapping, I have been running no a/c for about 2 years... I just (FINALLY) put in the a/c recently. When the a/c is off, the car idles fine, but when the car is idling w/ A/C on... it shakes like it's having a seizure..... steering wheel, loose change, things in my door pockets....you get the idea.
Well if I pump the brakes and the idle goes up a few rpm, the shaking goes away.... so I want to set higher.
What I DON'T understand is that the GSR ecu (which I'm running + uberdata) is supposed to have a feature that adjusts fuel or air intake to compensate for the compressor engaging, but that does not seem to be happening as idle will drop once the a/c comes on.
Old Apr 4, 2005 | 02:52 PM
billybong91DA's Avatar
just use a little pb blaster or break away, on the screw, try to do that first, use a bigger screwdriver second, and third, if that doesnt work, remove and clean the iac, or try to find a new tps... just a few suggestions, good luck
Old Apr 4, 2005 | 03:00 PM
AlxSiR7's Avatar
Default Re: (billybong91DA)
yes there will be some wax covering the tb screw if it's never been adjusted.. and the a/c will always drop the idle on our little 4 bangers
Old Apr 4, 2005 | 05:14 PM
X2BOARD's Avatar
^^ Yeah, but when I had my integras, the idle wouldn't cause an earthquake-like change in idle. Maybe it's just that civics are rattleboxes tho.... LOL
RDAYA0
16
May 1, 2008 10:25 PM
dek1mfk
Dec 4, 2006 08:05 PM
90_civic_Si
Oct 4, 2006 08:36 PM
crxste
10
Feb 28, 2005 09:18 PM
hatchfreak92
Oct 17, 2004 08:59 PM
