Camber Kit
Old Apr 4, 2005 | 01:46 PM
xla301's Avatar
Default Camber Kit
I just want to know is the camber is a "MUST" for a lowered car?? Or if I install the aftermarket camber kit, will my tires last longer??? And what does the camber kit do anyways??? I haven't seen a lot of people install that on their cars.
Old Apr 4, 2005 | 02:11 PM
migs's Avatar
Default Re: Camber Kit (xla301)
It is not a must. It is highly recommended that you get an alignment in which your toe angle will do most tire wearing.
Camber is responsible for 10-15% of your premature tire wear. There are a fair share of people who have them installed on their vehicles but again, its not a must.
In the long run itll last longer but not by much. Good luck. Come see me in Dallas to get an alignment
Old Apr 4, 2005 | 02:26 PM
xla301's Avatar
Default Re: Camber Kit (migs)
then... what brand will you suggest? And what is the difference between the camber kit and the Aligement kit???
Old Apr 4, 2005 | 02:33 PM
migs's Avatar
A camber kit usually consists of an entire upper control arm replacement or it replaces the existing anchor bolts. Anchor bolts secure the upper control arm to the car. I dont suggest this kit. Its difficult to adjust.
On the upper control arm unit, a slideable balljoint moves out and in. If you adjust it in, towards the engine, your increasing negative camber. If it slides out, it increases.......yes...positive camber.
Never heard of an alignment kit? You can get the alignment done at most service shops.
I suggest Skunk2 or Omni.
Old Apr 4, 2005 | 03:25 PM
xla301's Avatar
the Aligement kit is made by Eibach.... http://eibach.com/cgi-bin/html...23351 here's the link to the product.
Old Apr 4, 2005 | 04:03 PM
nadc2's Avatar
go with the skunk2 or omni
Old Apr 4, 2005 | 04:06 PM
totsie7944's Avatar
its not a must, your tires might last a little longer with one, but still just keeping it regularly aligned should keep your tires in pretty good working condition. If you drive hard tires aren't gonna last long any way
Old Apr 4, 2005 | 04:22 PM
jdmspoonitr's Avatar
Default Re: Camber Kit (totsie7944)
In simple terms when u lower your car the wheels will look like this fromt he back
// \\ .........not that exaggerated but u get the point. Camber kit allows adjustment for you to get you tires back to normal
ll ll so that all of the weight and pressure of the car is evenly distributed across the tire, instead of just on the inside of the tire
Old Apr 4, 2005 | 05:21 PM
migs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xla301 &raquo;</TD></TR><TR><TD CLASS="quote">the Aligement kit is made by Eibach.... http://eibach.com/cgi-bin/html...23351 here's the link to the product. </TD></TR></TABLE>
Ahh, they are calling parts "alignment kits"
BTW, those parts are junk, get Skunk or Omni
Old Apr 4, 2005 | 09:37 PM
Surfer_Sandman's Avatar
I think it depends on how low you go. I have a camber kit and it's very noisy. I don't knwo if it was needed but I figure it's better safe than sorry.
Old Apr 4, 2005 | 11:58 PM
itr1244's Avatar
Default Re: Camber Kit (Surfer_Sandman)
i got camber kits on my car and i NEEDED one.
i lowerd my car and my camber was real bad so i had to get them
you can use washers on the back but the front one.. you might need to get the kit.
well i got skunk2 front camber kit and goldline or something on the back.
hatch_
Feb 10, 2009 09:25 PM
BJA86
11
Sep 2, 2007 01:00 PM
imonx850
Suspension & Brakes
Mar 14, 2005 08:47 AM
JDMTurboEG6
Mar 11, 2004 07:53 PM
PorscheGT2
Dec 4, 2001 07:37 AM
