Will 92-96 Prelude radiator fit on 94-97 accord ? Also other simular question ?!?!
Old Apr 4, 2005 | 01:45 PM
efboy's Avatar
Default Will 92-96 Prelude radiator fit on 94-97 accord ? Also other simular question ?!?!
hi ... i have search and did not get a definate answer... just wanted to know if the
92-96 prelude will fit for the 94-97 accord?
Also i have a f22b jdm motor..just wanted to know what exhaust manifodl will fit ?
this is all going on a 94 accord
Which ecu should i be using, for now i have a 94 v-tec ecu..duno if it's ok or should i get the jdm one for it? thnkzx for anykind of help JJ!!
Old Apr 4, 2005 | 06:44 PM
efboy's Avatar
Default Re: Will 92-96 Prelude radiator fit on 94-97 accord ? Also other simular question ?!?! (efboy)
help anyone!???
Old Apr 5, 2005 | 04:44 AM
iakona's Avatar
i thought the fluidyne part numbers were the same for the 4th gen prelude and 5th gen accord, but check their site. that will tell you for sure.
use an H22 header for your F22B DOHC
and use the F22B DOHC ECU
Old Apr 5, 2005 | 07:51 AM
SearchBeforeUPost!'s Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">.
Nope, that wont fit. the bolts holes are different.
Old Apr 5, 2005 | 08:11 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">use an H22 header for your F22B DOHC
and use the F22B DOHC ECU</TD></TR></TABLE>
No and........NO. Use an H23 header as the F22B DOHC is almost exactly the same as an H23 and the H22 header will NOT fit on an H23.
Old Apr 5, 2005 | 10:07 AM
iakona's Avatar
damn it. my bad. H23. i was too slow this morning.
Old Apr 5, 2005 | 12:31 PM
efboy's Avatar
THNKXC ALOT guys... BTW any body got the exhaust manifold for it in socal..so i can pick one up ??
but is it require to use the F22B JDM ECU??
Cause i got 94 Ex v-tec ecu for cheap...
would that be good enough...?&gt;
i just check the part number and it seems to be the same !!
so i guess it will fit with no problem then !! GOOD **** !!
Modified by efboy at 9:43 PM 4/5/2005
Old Apr 6, 2005 | 09:59 AM
efboy's Avatar
Default Re: (efboy)
Old Apr 6, 2005 | 10:02 AM
-RedneckDave-'s Avatar
Working
Default Re: (efboy)
You will need to use the jdm f22b ecu with that motor if that is the motor you have. I would think that there would be too many differences to use the sohc ecu
Old Apr 6, 2005 | 10:28 AM
efboy's Avatar
Default Re: (-RedneckDave-)
u think it will run like **** or what ?? how about the h23 ECU i think it's p14 or somehting rite??
Old Apr 6, 2005 | 10:31 AM
iakona's Avatar
you could try and compare the wiring pinouts for the P14 and the JDM F22B ECU. that would give you the best idea of whether or not it would work.
ram0869
May 30, 2008 04:43 PM
GoCarInteg
Dec 11, 2005 12:42 PM
yamaha-sc500
Dec 2, 2005 03:58 AM
