car has trouble starting?
Old Apr 4, 2005 | 12:07 PM
KingJeff's Avatar
Default car has trouble starting?
My car has trouble starting. When I turn the key, it struggles for 2 seconds before it starts. It sounds like it is about to die, then it starts. A day before, it would make any sound at all. It would start unless i keep clicking it over a few times. The battery is 3-4 months old and also bought a starter. Could it be the alternator?
Old Apr 4, 2005 | 03:23 PM
KingJeff's Avatar
Default Re: car has trouble starting? (KingJeff)
ttt
Old Apr 5, 2005 | 07:46 PM
stumpyf4's Avatar
Could be the alternator... check the easy stuff first, make sure all the connections to the battery and starter are tight and free of corrosion.
Old Apr 6, 2005 | 09:05 PM
AkademikONE's Avatar
Check the alternator. Clean your battery terminals also.
Old Apr 10, 2005 | 03:13 PM
KingJeff's Avatar
Default Re: (LeClkMyDeClk)
just changed the plugs today, car still has trouble starting!!! It would take me about 30 attempts to start. And when it does start...it sounds like a bad cough, then it starts.
Old Apr 10, 2005 | 05:27 PM
stumpyf4's Avatar
Default Re: (KingJeff)
Sound like it has no trouble turning over since you can do 30 attempts and still have enough battery power.
Check spark and fuel.
What the condition of the cap and rotor... look inside the cap and inspect the terminals, do they have a nice appearance on the surface that touches the rotor? Or a crusty film? If a crusty film replace the rotors and cap as a set.
Fuel... you're gonna want to check the fuel pressure.
Old Apr 10, 2005 | 07:34 PM
KingJeff's Avatar
Default Re: (stumpyf4)
im pretty sure cap and rotor havent been changed in a while. HOw do I check the fuel pressure? Thanks.
hmtcrxsir
34
Aug 10, 2007 12:21 AM
SiB16A
Jun 11, 2006 12:37 PM
95greenteg
Nov 29, 2004 02:56 PM
int3gra
May 16, 2002 08:51 AM
riceanator01
May 8, 2002 01:07 PM
