install cam gears and pullys h23a1
93 prelude si h23a1. i just bought u.r. pully set ant tuner cam gears. once i uninstalled alot and loosened the timing belt and installed the new cam gears i have to readjust tension back in2 the belts (my car has a timing belt and timing balancer belt). to do it i got slack between the cams, loosen & tighten adj nut, and turened 3 teeth movin slack to the tensioner side loosen & tighen again 33 ft pd. the timing belt is fairly tight but the balancer belt is loose compaired to timing belt not loose enough 2 skip but loose is this rite?? if not how do i get them both tight? also my stock crank pulley had a lg hex shape in it for a removal tool witch i used to get it off, my new pully has no hex. what is the best way for me to retighten it? can i just jam the pully with a lg screw driver it looks like i'll be able to do that, but i need to put 160 ft pd tq on it may be alot to hold back. i have a impact with a 160 tq stick on it. help plz!
Modified by balbowskie187 at 3:19 AM 4/6/2005
Modified by balbowskie187 at 12:11 PM 4/7/2005
Just put my engine back together, I look at the timing belt and its loose in between the cam gears??
Thrillhouse
Aug 7, 2004 10:07 AM
