I can't check CELs.
Old Apr 4, 2005 | 10:16 AM
JDM-EJ1's Avatar
Default I can't check CELs.
I read the write-up on how to do it and what not, so I found that wire (the one with the 2 prongs, not 3) and trough and jammed a paperclip in there. I turn my ignition to the accesorries, my CEL goes out (like normal) and my SRS light starts flashing. Any ideas?
Old Apr 4, 2005 | 11:18 AM
wilsel's Avatar
Default Re: I can't check CELs. (JDM-EJ1)
Was the CEL on while driving before you jumpered the connector? The flashing SRS light means you jumpered it right, and that it's in diagnostic mode. The CEL will come on solid for a couple seconds, then it'll go out, and then it should flash any codes (if there are any stored).
Old Apr 4, 2005 | 11:57 AM
Bond's Avatar
Default Re: I can't check CELs. (wilsel)
If it's not flashing thats a good thing too. Like said before if there has been a check engine light before it stores the code, when you jump it it will display the code. No code then no problems.
Old Apr 5, 2005 | 04:07 AM
JDM-EJ1's Avatar
Default Re: I can't check CELs. (Bond)
Oh, well that's good to know. Thanks guys.
Old Apr 5, 2005 | 11:55 AM
Bond's Avatar
NP .
redman223
Jul 13, 2008 01:37 PM
MOVE OVER
Jan 18, 2005 09:10 PM
smithbling
Nov 19, 2002 12:26 PM
S13 slide
Oct 8, 2002 01:23 PM
