Bearing Size or kit For B20's
Old Apr 4, 2005 | 07:27 AM
ek2k's Avatar
Default Bearing Size or kit For B20's
Wats up everyone,
Im trying to see if someone can help me out get the right size of ACL bearings for my b20 vtec motor i need the main bearings, rod bearings, and thrust washers.
Which kit should i go for because i dont think there is a specific kit for b20's yet or maybe correct me please. i do have eagle rods so if that matters in any case as far size can someone help me please.
Old Apr 4, 2005 | 07:28 AM
ek2k's Avatar
Default Re: Bearing Size or kit For B20's (ek2k)
Bump for an answer i need.
Old Apr 4, 2005 | 07:36 AM
EG-B20vtec's Avatar
These motors share the same Main Bearings, Con-Rod Bearings, and Thrust Washers.
• B20b,z
• B16a1,a2,a3
• B17a
• B18a,b
Old Apr 4, 2005 | 08:23 AM
ek2k's Avatar
Default Re: Bearing Size or kit For B20's (EG-B20vtec)
thanks alot eg b20 vtec so should i just go ahead and place an order and ask them to give which ever one since they are all the same size?
Old Apr 4, 2005 | 08:25 AM
ek2k's Avatar
Old Apr 4, 2005 | 01:52 PM
EG-B20vtec's Avatar
Yeah, just order the LS Set and Be done with it.
Old Apr 5, 2005 | 03:04 AM
EG6R's Avatar
EG-B20vtec: 214whp. whats your setup?
Old Apr 5, 2005 | 04:44 AM
Vsm Hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-B20vtec &raquo;</TD></TR><TR><TD CLASS="quote">These motors share the same Main Bearings, Con-Rod Bearings, and Thrust Washers.
• B20b,z
• B16a1,a2,a3
• B17a
• B18a,b
are you sure about that? i always thoguht the
b18c and b18b's were the same, but not sure about the othres...
BUt the b16's had a different bearing?
I found this out when i was looking for OEM bearings. Honda bearings cost half the price of Acura bearings so I figured I could run b16 bearings in a b18c to save money. Until i found out b16 bearings didn't fit...
does anyone have comfirmation of this? or other wise?
Old Apr 5, 2005 | 06:06 AM
ek2k's Avatar
Default Re: Bearing Size or kit For B20's (LazyNip)
bump for and answer and i bought my kit already i ordered the b18 a/b which is the same for b20's should be here tomorrow cant wait.
rwautomotive
Engine Machining & Assembly
Jul 26, 2015 07:35 AM
92integraVTECgsr
May 13, 2008 09:31 PM
Thepanda
May 17, 2007 06:22 AM
Bevenue
11
Jan 7, 2007 09:43 AM
turboex
Jun 14, 2004 01:27 PM
