How to tell if motor mounts need replacing?
Hey everyone, I might be purchasing new motor mounts as I feel that the old ones are going bad, but I need a sure way of knowing this. Suggestions welcome! TIA
when they're real bad the vibrations from the motor are pronounced inside the car.
otherwise you could notice excessive torqueing of the motor when it's revved.
If you ever dyno your car, you will know what Jesse is talking about. You can see the engine moving when you are reving up the engine.
Jesse, could you explain this a bit further? Thanks!
Also forgot to mention, look for cracking or tearing within the rubber. That's clear indication for replacement.
An engine lift makes things much easier,
but if you're crafty, a good floor jack and extra hands would work also, just more difficult.
Replacing the mounts are easy since it only involves a bolt. Getting to them and lining up the motor to the mount is the tricky part.
I'd also like to add that if your shift lever moves alot when u let off the gas while you are drivng, its also a good sign that your mounts are bad...
Thanks for everyones responses, I'm gonna check it out right now. I've been wondering b/c even in second gear, with the car moving, no gas applied, the car is jerking like a ****. Thnx again all.
