Quick suspension question
Ok pretty soon I will be getting my B&G springs and Koni adjustables. My question to all is do you think I might need a camber kit to get the R aligned. The drop from the springs is 1.25. TIA
Is the car just street driven? Your camber will not be all that bad with that drop but you will need to get an alignment anyway to get everything back where it should be. If your concern is tire wear be sure that your toe settings are correct. Most people here get camber kits to put MORE negative camber in the front for better grip while cornering.
Yeh it is my daily driver. I had the question because when I talked to B&G they said they were not sure if i'd need one to bring my car back to spec without a camber kit. They said I should be able to.
draco067
Feb 2, 2003 07:18 PM
