eK hatch fuel system pressurization problem / idle problem
my car (2000 civic) seems to suck gas... and when i open the fuel cap, it does not give the vacume sucking sound it should... any ideas why? anyhting i should look at?
i've dont the obvious of looking at the tank and seeing if anythings busted. buit it looks fine..
and on to the idle problem, only once it's warmed up, it gives a surging idle. what to loook for there?
no cels.
thanks
no cels.
thanks
Pic no worky. I would guess that you have a leak because you don't have vacuum from the fuel pressure. Check your fuel rail, injectors, all fuel lines and fuel filter housing for bad seals. If your tanking up like everyday I would have to guess that the fuel is going somewhere else it shouldn't be. Maybe fuel pump is going and not keeping pressure. If it is stalling or just bad running could be fuel pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond »</TD></TR><TR><TD CLASS="quote">Pic no worky.</TD></TR></TABLE>
haha, no he was sayin maybe when people see a picture next to the title theyll click on it because people usually wont read it if there isnt.
bump
bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie »</TD></TR><TR><TD CLASS="quote">
bump </TD></TR></TABLE>
What the hell is that blue box below what he said then. I don't know, I'am tierd
Free bump for you though.
.Free bump for you though.
go in to a little more detail with the idle thing your talking about i have a 2000 civic and i think mine is doing the same thing?
EFn-DirtySouth
19
Apr 5, 2014 04:24 PM
