Help with a small enclosure and with lots of bass.
Old Jan 27, 2002 | 08:03 PM
AlphaKennyWun's Avatar
Default Help with a small enclosure and with lots of bass.
I have a clean 400 watts for bass in 1 ohm mono .5 inch stereo with an Orion HCCA 225 amp. I want a smaller box than my 12s RF HE2 in a 1.5 cubic inch per 12 enclosure. It sound pretty good right now.......but I know I can get more sound with less space maybe 2 10s or even 3 8s? JL Audio? MA audio?
Oh yeah must be dual voice coil to bridge the amp. Dont want to spend more than 100-200 per speaker.
Old Jan 28, 2002 | 07:32 PM
MugenSi00's Avatar
Default Re: Help with a small enclosure and with lots of bass. (SO3Burner)
I'd go with either a pair of JL or RF 10's.
Old Jan 28, 2002 | 07:37 PM
Default Re: Help with a small enclosure and with lots of bass. (MugenSi00)
I was thinking about this.....two kicker 8" solobaric squares. That box would be smaaaalllllll!!!
[Modified by SO3Burner, 4:41 AM 1/29/2002]
Old Jan 29, 2002 | 07:05 AM
carolinaACCORD's Avatar
the l7's are a good idea, but if you want to small box them, be ready to put some more power on them.
i had 2 12" l7's (dual 2 ohm vc) and built the enclosure to Kicker specs.
first i tried it with a ZR120 (at 4 ohm mono)=couldnt hear the subs.
then went to a ZR600=barely hearf it
3rd i tried two ZR600's=finally started to get loud
then i eventually went with two memphis ST1000D (at 1 ohm)retty damn loud
but you know, now i have switched to just one l7 12"
in a 3.5 cubic feet box and a ZR360, and it outdoes the 2 12's!
Old Jan 30, 2002 | 07:13 PM
Default Re: Help with a small enclosure and with lots of bass. (mugenACCLUDE)
up
Old Jan 30, 2002 | 08:13 PM
MachAF's Avatar
JL w0's.
JL makes a box that fits in the spare tire well of integras that will hold 3 10 w0's.
Old Jan 31, 2002 | 12:55 PM
SiClone's Avatar
Agreed! I have 1 S12L7 in a 3.25 cu ft box with a 200 watts off my PPI PC4800 (for now) and it slams.... Ported box is the best way to go for L7's!!!
Old Jan 31, 2002 | 07:39 PM
Default Re: Help with a small enclosure and with lots of bass. (SiClone)
Yeah I saw that very same box for the integra spare tire hole.....but I finally decided I cant give up my spare tire. I run over nails probably several times a year and being without a spare when you get a flat is one big headache!
Old Jan 31, 2002 | 10:05 PM
TexTeg's Avatar
Look into memphis subs. A pair of st1000d's would put down some noise.
[Modified by TexTeg, 11:05 PM 1/31/2002]
Old Feb 1, 2002 | 09:35 PM
o_Rage_o's Avatar
Default Re: Help with a small enclosure and with lots of bass. (TexTeg)
your running 400 watts split between two subs, or 400 watts rms each? If it's 200watts rms to each sub, consider getting a bigger amp.
Best bet , jbl 1200.1 off ebay, it's dirt cheap and provides you with great clean power.
Look into it!
Old Feb 7, 2002 | 02:41 AM
gsr98vtec's Avatar
Default Re: Help with a small enclosure and with lots of bass. (o_Rage_o)
3.5cu ft per 12 is not a small space
how bout 1 cu ft per 12 with 400 watts per sub thats a small space high power setup
SD1222
Audio / Security / Video
Feb 15, 2006 11:26 AM
97VtecIN
Feb 2, 2005 04:57 PM
lilbennyxx
10
Oct 11, 2003 12:10 PM
AWDxBOOST
Apr 14, 2003 06:59 PM
loki2323
Dec 20, 2002 12:55 PM
