Suspension & Brakes Theory, alignment, spring rates....
ITR suspension on my EF9?
Old Apr 3, 2005 | 08:04 PM
RHDwhor3's Avatar
Default ITR suspension on my EF9?
ok im looking to get some new suispension for my 1990 Ef9 i was looking under the car and i noticed the rear LCS's looked liek my old SIr-g integra ones ( same as ITR ) so i was wondering um.
Are the rear LCA's for the 90 SIR the same as the ITR ones? so then can i run ITR suspension or what
i searched and all i found was info and tips for the US 88-91 hatch so any info would be great..
Thanks
Gary
Old Apr 3, 2005 | 08:51 PM
RHDwhor3's Avatar
Default Re: ITR suspension on my EF9? (givbloodsk8)
BUMP
Old Apr 4, 2005 | 02:51 PM
ShiroX's Avatar
you will have to run ITR Suspension Type Suspension ( eye mount style) on the rear or switch out the rear control arms to the US Fork Spec to run US Spec Suspension.
if you decide to stay with the ITR type you will need EG/DC forks for the front
the only downside to using ITR suspension is that the front is taller by maybe 1.5"-2.0" giving a not so aggressive stance and lowering the car too much will lose suspension travel
I am currently using ITR BuddyClub Race Spec Damper w/ Upper Pillowball Mounts on my EF and to achieve a nice stance i have the Sus all the way down on the fronts, but because of the stiffer spring rates and adjustable dampening the ride/performance is not affected.
Old Apr 5, 2005 | 03:26 PM
RHDwhor3's Avatar
Default Re: ITR suspension on my EF9? (VTeC4TheChildren)
Thanks bro.. bump for people liek you!
Old Apr 5, 2005 | 04:41 PM
erikiksaz1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTeC4TheChildren &raquo;</TD></TR><TR><TD CLASS="quote">
You should give this some thought. By going with the ITR shocks, which are 1.5-2" taller (as he says), you're losing out on suspension travel. And i'm guessing it would raise the car. Lowering it would again cause you to lose suspension travel.
Why not just buy shocks that were meant for your car? The rears are probably the same as the ITR (box type), so you don't have a choice. But, the front...
Old Apr 5, 2005 | 08:15 PM
RHDwhor3's Avatar
Default Re: ITR suspension on my EF9? (erikiksaz1)
WEll wtf
i need to figure this out i guess im pretty much wondering aobut the HKS hipermax II suspension for the ITR i wann know if that will work.. i dunno how it can be 2" taller hmm
well i have to mix and matcha round her unless i go with TEin for the JDM ef9 cuase all the dam ED9 BS rear LCA's
So i know the rears for the ITR will work J/w what for the fronts
anyone have any ideas ..
Old Apr 7, 2005 | 06:13 PM
ShiroX's Avatar
if you want to go with a true JDM damper/coilover set then its gonna be hard to find anything but the TYPE R to work
if you go with say, konis, then you could buy the ITR rear struts and crx fronts struts and be okay.
if you want super slam with good ride, then find some 86-89 Accord bilstein struts, an inch shorter than crx (this is for thr Front only BTW)
I currently have buddy clubs on my EF and it is plenty low and because spring rates are soo stiff and the damper is set almost to max, the shock has yet to bottom out
before i the buddy clubs i used Daiyama BBI for ITR and ride was excellent and drop was nice also
Old Apr 7, 2005 | 06:16 PM
ShiroX's Avatar
more pics here
https://honda-tech.com/zerothread?id=1109460
Old Apr 7, 2005 | 10:14 PM
erikiksaz1's Avatar
Follow this man's advice:
ITR rears
86-89 Accord Fronts
Only works if you will be using coilovers though.
SpoogenJay
Feb 28, 2006 03:43 PM
StickyGreen
Jan 9, 2006 05:06 PM
OnePointFive
May 17, 2004 08:53 AM
tweekerz
May 6, 2002 05:59 AM
