5 lug conversion problem
Old Apr 3, 2005 | 08:03 PM
go2sleep's Avatar
Default 5 lug conversion problem
has anyone tried to do a 5 lug conversion on an integra w/out getting the itr rear trailing arms? it seems to me that the itr has a longer spindle and the rear hub wont be seated properly on a regular integra arm.. so..has anyone gone through this procedure?
Old Apr 4, 2005 | 09:31 AM
Demented's Avatar
Default Re: 5 lug conversion problem (go2sleep)
Yes, When I bought my 5 lug conv. one of the trailing arms where bent so I used the stock arm and it worked fine. They look the same to me.
Old Apr 4, 2005 | 11:40 AM
go2sleep's Avatar
did the spindle nut thread all the way so you could notch it?
that's the problem im having. the nut is already tight, but the spindle itself it too short so i cant notch anything.
Old Apr 5, 2005 | 11:43 AM
go2sleep's Avatar
Default Re: (go2sleep)
anyone with a suggestion?
Old Apr 6, 2005 | 09:40 AM
b18ccivics's Avatar
is the old bearing race still on the spindle?
Old Apr 7, 2005 | 06:22 PM
go2sleep's Avatar
Default Re: 5 lug conversion problem (b18ccivics)
nope. the old race came off with the origninal hub
Old Apr 7, 2005 | 06:36 PM
EH3-R's Avatar
you need itr spindles, but the itr spindles can't be purchased without the trailing arm as one piece, at the dealer of course
Old Apr 7, 2005 | 11:53 PM
go2sleep's Avatar
would crv (fwd), rear spindles work> if not, i'll just have a buddy fab up a "cotter pin" to keep the nut in place, with lock tite, of course
Old Apr 8, 2005 | 10:54 AM
Purple_Civic's Avatar
Could you use a 5 lug hub out of a 97 prulude?
Old Apr 9, 2005 | 12:07 AM
go2sleep's Avatar
i doubt it. give it a shot and let me konw.
Old Apr 9, 2005 | 11:06 PM
PrettyLude's Avatar
Default Re: 5 lug conversion problem (Purple_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purple_Civic &raquo;</TD></TR><TR><TD CLASS="quote">Could you use a 5 lug hub out of a 97 prulude?</TD></TR></TABLE>
i don't think u can, i might be wrong though
Old Apr 12, 2005 | 06:59 PM
djprettyrick's Avatar
Default Re: 5 lug conversion problem (PrettyLude)
Demented
you had no problem with just using a itr hub on the integra rear? i heard you can just use itr hubs with stock integra suspension just get the fronts pressed on? anyone know anything about this?thanks in advanced
Old Apr 14, 2005 | 10:41 AM
Default Re: 5 lug conversion problem (djprettyrick)
anybody?
Old Apr 14, 2005 | 12:54 PM
Demented's Avatar
my rear conv. came with the hub and trailing arm but one was bent so I used my stock one. Fot the front I believe I just used the hub.
xlasianizelx
Jan 13, 2011 05:54 PM
JDM_SOHC
May 22, 2006 05:48 AM
fabworxs
Feb 17, 2006 04:17 PM
One Bad GeeSeeR
Jun 24, 2004 02:49 PM
