Y8 air/fuel delivery upgrades
I'm about to swap a Y8, and the motor doesn't currenty have IM/fuel rail/injectors, so I figure why not go aftermarket. I've been looking into the Edelbrock IM, but haven't ruled out an OE Y8 IM. I don't know what injector/fuel rail combo to go with, suggestions???
yeah stock fuel rail and injectors should do fine.
You could go with the aftermarket IM if you wanted, i have heard good things about the Skunk 2 IM on NA cars, if you are planing on later going turbo i would get the Edelbrock though .
good luck dude
good luck dude
yes and no the manual has the idle air control valve on the back and the automatic just has a machined place for it to go. The IACV is up under the throttle body on the automatics. there could be different placement of a vacume line or something but i can't remember?
thats about the only and biggest difference i can think of
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCivExoo »</TD></TR><TR><TD CLASS="quote">yes and no the manual has the idle air control valve on the back and the automatic just has a machined place for it to go. The IACV is up under the throttle body on the automatics. there could be different placement of a vacume line or something but i can't remember?
thats about the only and biggest difference i can think of</TD></TR></TABLE>
Manual = 2 wire IACV.
Automatic = 3 wire IACV.
leroyb
Jun 19, 2009 12:13 PM
pornstarSR
Aug 6, 2003 09:01 PM
