HELP: 96 ls turbo is not boosting
Old Apr 3, 2005 | 05:30 PM
94_civicEx's Avatar
Default HELP: 96 ls turbo is not boosting
i just got done with my 96 civic hatch with 97 ls motor with .002 overbore in it and i hooked all the turbo parts on but not the b.o.v piping and raced my bubies nx2000,b16 civic and an 91 sertra ser to see what my motor would do but i lost to all three of them it feels so weak. then i decide to hook on the b.o.v pipe and i'm not getting no boost. i checked all the clamps but it all good took it around again and still no boost. any ideas
Old Apr 3, 2005 | 05:37 PM
hatch34's Avatar
Default Re: HELP: 96 ls turbo is not boosting (94_civicEx)
waste gate stuck open?? maybe?
Old Apr 3, 2005 | 05:39 PM
Luserkid's Avatar
Default Re: HELP: 96 ls turbo is not boosting (hatch34)
Do you have a boost gauge? What type of kit? Vaccum leak? Hear your turbo spool? etc.
Dude you left out enough info to fill a library.
Old Apr 3, 2005 | 06:08 PM
94_civicEx's Avatar
Default Re: HELP: 96 ls turbo is not boosting (Luserkid)
i'm using an internal waste gate,t3 turbo,custom pipings,and when i step on it i don't hear the turbo spool but when i cover the air inlet it sucks realy hard when i rev it, and i step on it i don't hear the b.o.v
Old Apr 3, 2005 | 06:11 PM
SOHCD16y8's Avatar
Most likely a wastegate problem, did you try working the lever manually, vacuum line is attched correctly
Old Apr 3, 2005 | 06:14 PM
94_civicEx's Avatar
Default Re: (SOHCD16y8)
on the internal wastegate i was messing around with the lever
and is an ls in a 96 civic hatchback that slow?? i thought i would do better or beat an stock 91 sentra ser??
Old Apr 3, 2005 | 06:36 PM
LShatchie's Avatar
Default Re: (94_civicEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_civicEx &raquo;</TD></TR><TR><TD CLASS="quote">on the internal wastegate i was messing around with the lever
and is an ls in a 96 civic hatchback that slow?? i thought i would do better or beat an stock 91 sentra ser??</TD></TR></TABLE>
yeah man something is definatly wrong, you should have beat the sentra
Old Apr 3, 2005 | 09:56 PM
Otherguy's Avatar
NASIOC.com
Default Re: (LShatchie)
Did you hit the on switch =D
Old Apr 3, 2005 | 09:58 PM
Luserkid's Avatar
Default Re: (Otherguy92)
Check to make sure all your pipping is connected. I just finished working on a car and his problem was that one of his couplings were not on on the way. Check that then check for boost leaks on your "custom" intercooler pipping.
Old Apr 3, 2005 | 10:08 PM
Built to Spill's Avatar
el diablo
Default Re: (Luserkid)
*sigh* Please check all your piping, couplings, and lines. There is definetly a leak somewhere
Old Apr 4, 2005 | 03:21 PM
94_civicEx's Avatar
Default Re: (Built to Spill)
ya i check all the clamp again but it's all tight i'm think it maybe a lever to the internal waste gate
Old Apr 8, 2005 | 12:00 PM
94_civicEx's Avatar
could not having an o2 sensor and crank sensor make the car slow??
Old Apr 8, 2005 | 12:19 PM
ssbpturbohatch's Avatar
sounds like a boost leak but you may wanna try the forced induction forum
JuicedUpRice
Oct 7, 2012 07:16 PM
Sic_DA_Nine
Mar 8, 2008 07:14 PM
jfruauff
May 22, 2007 07:34 PM
