will this work?
Old Apr 3, 2005 | 05:27 PM
drowzysleeper's Avatar
Default will this work?
i have a d16y8, with intake header, & test pipe. was wondering if i put p29 pistons in it if i would need to change out the rods to withstand all that compression. i think i will be running about 12-4-1. then i was going to get a cam and cam gear, with a vtec controller anyone have any input? one more thing does anyone know how i can get my ecu chipped for all that ****? im not sure how that is done.
Old Apr 3, 2005 | 05:54 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: will this work? (drowzysleeper)
as far as the chip goes, are you obd1 or 2? if you are 2 you cant, till you convert to 1, and if you do an afc for a vtec controller you wont need a chip. and as far as your rods go, i cant answer that. but you may be ok as long as you stay away from boost and spray.
Old Apr 3, 2005 | 05:55 PM
civictildeath's Avatar
try 13.6:1 compression http://www.knology.net/~jediklc/D.htm
that is way too much for the gaskets to handle
Old Apr 3, 2005 | 05:57 PM
Mr. Badwrench
Default Re: will this work? (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">try 13.6:1 compression http://www.knology.net/~jediklc/D.htm
that is way too much for the gaskets to handle</TD></TR></TABLE>
thats a bad *** calculator.
Old Apr 3, 2005 | 06:14 PM
Mr. Em1's Avatar
true that, that calculator thing is madd cool
Old Apr 4, 2005 | 08:24 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drowzysleeper &raquo;</TD></TR><TR><TD CLASS="quote">was wondering if i put p29 pistons in it if i would need to change out the rods to withstand all that compression.</TD></TR></TABLE>
No, no need to change them, however shot peening would not hurt
Cryo-treating would be even better!
Old Apr 4, 2005 | 01:30 PM
Default Re: will this work? (civic-4-ges)
what could i do to use those pistons? that calculator is cool but did you use the formula at the bottom?
Old Apr 4, 2005 | 02:40 PM
Formula at the bottom???
When entering info for those pistons, make sure to use the correct piston to deck height. Typically it is stated to be .040", but I found mine to be .045". In terms of compression, thats only a little difference (.040-.045 that is).
to run this setup, you would ideally need a thicker than average headgasket, along with extra fuel and conservative timing. Unless you tune your a/f ratio and work your timing.
Old Apr 4, 2005 | 03:09 PM
ok well im gonna probably have to buy a block guard then what do you guys think?
Old Apr 4, 2005 | 04:53 PM
Blockguard is a little extra insurance, but only a handful of people running p29's use one
Apple395
Sep 26, 2014 06:32 AM
Haleiwa-Brando
12
May 14, 2006 10:46 AM
RTst92
Mar 5, 2006 01:56 PM
c1civic
Apr 8, 2005 10:02 AM
Curtisbeef
Sep 25, 2004 07:33 PM
