CEL HELP!!
ok as i have posted in this thread about my prob. about my ITR manifold idle problem..that we fixed i now have ANOTHER problem...the problem last time was the TPS sensor loose NOW the idle will stay at 2k and i have screwed in the idle screw all the way in...and i have a CEL which is !....!....!!!! which is 24 but i dont see any 24's on the ECU threads..could anyone help??
Sounds like your throwing 2 codes over that 1 that you think.
I think your throwing 1 and 14 which makes alot of sense to this thread:
1 O2A - Oxygen sensor #1
14 IAC (EACV) - idle air control valve
Check your IACV, and also clean out your FITV and your idle should be fine.
dont mouth newb.. You would have never had to make this thread if you knew how to check your cel's IACV just a search.. There is over 20 topics for it.. https://honda-tech.com/search
918 - shut the **** up, you have your own problems to deal with. I dont think you want people to come into your VAFC thread that you bump every 15 seconds just to tell you to search.
Heres how to fix the FITV
https://honda-tech.com/zerothread?id=699787
For the IACV, just take it off and spray it with carb cleaner and that should help you provided it worked before.
