What have I overlooked?? (56k Run and Hide)
Old Apr 3, 2005 | 03:45 PM
XSIintegra's Avatar
Default What have I overlooked?? (56k Run and Hide)
Ok, I go to fit my Turbo today and I ran into a problem. From what I can tell, I need to grind out about a 1/2" more aluminum for the turbo to fit. Problem being, I don't have any more metal to grind off. The inlet of the turbo is already resting against the block. Hopefully, I'm just way to f*cking tired right now, and overlooked something. I've got another 1/8" worth of metal I could take out, but that seems to be it.
rigging:
RevHard Mani
run of the mill t3/t4
Old Apr 3, 2005 | 03:58 PM
rainmanEK's Avatar
big strong guy
Default Re: What have I overlooked?? (XSIintegra)
Clock the turbo, It makes a differnce!
I made this same mistake......
Eric
Old Apr 3, 2005 | 04:27 PM
vr6chris's Avatar
Default Re: What have I overlooked?? (rainmanEK)
you running a tang. housing? may have to go to an oncenter housing to clear it.
Old Apr 3, 2005 | 04:42 PM
SHystrdyGSRtdy's Avatar
Default Re: What have I overlooked?? (vr6chris)
if clocking the turbo doesn't work... was your turbo inlet meant to face the driver side?
Old Apr 3, 2005 | 04:48 PM
SOUNDEFFECTS's Avatar
Default Re: What have I overlooked?? (SHystrdyGSRtdy)
something wrong, don't cut anymore, it looks like you have a on center housing on it, you need a tang housing
Old Apr 3, 2005 | 04:49 PM
EJ1 wilcox's Avatar
I would flip it around and have the compressor on the driver's side... less hassle IMO...
You might not have any other options...
Old Apr 3, 2005 | 04:55 PM
powerofdreams8's Avatar
Default Re: What have I overlooked?? (EJ1 wilcox)
You can shave more off. I have seen blocks shaved all the way down to where the block code is just "B" - rather then B18C.
Old Apr 3, 2005 | 05:13 PM
mtber's Avatar
You still can shave more off. I had to on 2 of my setups.
Old Apr 3, 2005 | 05:23 PM
TurboTagTeam's Avatar
Default Re: (mtber)
Mine is shaved down alot more than that.
And since you are using a Rev-Hard manifold im assuming you'r using a Rev-Hard downpipe, so if you turned the compressor to the drivers side you would have to get a new downpipe.
Old Apr 3, 2005 | 05:33 PM
XSIintegra's Avatar
Default Re: (TurboTagTeam)
I've tried clocking the housing with no success. I've also tried pointing the intake towards the drivers side, but the exhaust housing then hits the radiator....
Seriously...WTF!
Am I looking at getting a different Mani? I already removed the A/C so....
Old Apr 3, 2005 | 06:07 PM
LSVtechnologytur...'s Avatar
Default Re: (XSIintegra)
are you hitting that plug?
Old Apr 3, 2005 | 06:09 PM
turboEGhatch's Avatar
Default Re: What have I overlooked?? (SOUNDEFFECTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOUNDEFFECTS &raquo;</TD></TR><TR><TD CLASS="quote">something wrong, don't cut anymore, it looks like you have a on center housing on it, you need a tang housing</TD></TR></TABLE>
That's a T3 turbo, and to the best of my knowledge there are no different on center or tang T3 housings.
Old Apr 3, 2005 | 06:21 PM
DC_andrew's Avatar
On my revhard kit I had this same problem and had to use a cast spacer between the mani and head to get it to fit.
Old Apr 3, 2005 | 06:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIintegra &raquo;</TD></TR><TR><TD CLASS="quote">I've tried clocking the housing with no success. I've also tried pointing the intake towards the drivers side, but the exhaust housing then hits the radiator....
Seriously...WTF!
Am I looking at getting a different Mani? I already removed the A/C so....</TD></TR></TABLE>
get a half size radiator
Old Apr 3, 2005 | 08:24 PM
XSIintegra's Avatar
Default Re: (vtec'n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec’n &raquo;</TD></TR><TR><TD CLASS="quote">are you hitting that plug?
No, I've got about a 1/8" space from that plug. The Inlet is touching before the plug.
I'm not Kosher with cutting into the block much more. Sure I could shave off another 1/8", but that still leaves me out 3/8" and I hate the idea of have the intake stuffed right into the side of the block.
Where would I get a spacer? Are you talking about using a something like a flange for building manifolds?
Its either that, or go w/ a civic radiator, which would make life rather simple. And being that this is going on a DA with a huge front crossmember, reverse mounting would make the DP even easier to run.
Old Apr 3, 2005 | 08:30 PM
boostedef9's Avatar
thats not a rev hard manifold thats a drag you can tell by the wastegate is more to the center on a rev hard
Old Apr 3, 2005 | 08:32 PM
Groovinator's Avatar
tight fit.
i might clock it to get a better outlet for the IC piping.
Old Apr 3, 2005 | 08:40 PM
XSIintegra's Avatar
Default Re: (Groovinator)
clocking it any other direction only makes the problem worse. I've got the smallest part of the housing against the engine right now.
Old Apr 3, 2005 | 08:48 PM
mtber's Avatar
Well, make it fit.
Old Apr 3, 2005 | 09:02 PM
mike93eh
Guest
Posts: n/a
Default Re: (DC_andrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_andrew &raquo;</TD></TR><TR><TD CLASS="quote">On my revhard kit I had this same problem and had to use a cast spacer between the mani and head to get it to fit.</TD></TR></TABLE>5
this is what i would do...
Old Apr 3, 2005 | 10:36 PM
RACEPAK's Avatar
please post a picture of your setup..... i want to see how it looks with the spacer....
Old Apr 4, 2005 | 06:50 AM
XSIintegra's Avatar
Default Re: (RACEPAK)
Well, I'm probably going to go ahead and switch to a civic radiator and just flip the turbo.
Before I do that, I would like to see any pix w/ a spacer used or pix of someone with the same setup, showing how much the cut out of the block.
Old Apr 4, 2005 | 07:35 AM
Burke's Avatar
Banned
have you thought about using a head flange as a spacer and just getting longer studs?? i've got a 3/8's cnc'ed one if you need it. pm me if so or steal one of your friend's
Old Apr 4, 2005 | 07:52 AM
Evanmb44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIintegra &raquo;</TD></TR><TR><TD CLASS="quote">Well, I'm probably going to go ahead and switch to a civic radiator and just flip the turbo.
Before I do that, I would like to see any pix w/ a spacer used or pix of someone with the same setup, showing how much the cut out of the block.</TD></TR></TABLE>
this route is going to be your best bet for fitment purposes. and you will have a shorter downpipe
Old Apr 4, 2005 | 08:07 AM
tgreaves's Avatar
Default Re: (Turboaddict)
I would turn the turbo around so the compressor is on the drivers side..
