anyone running the kosei K1 TS?
i'm looking into these wheels and ive search, but all i get are FS threads. i read one thread that said the 205 azenis rub. but its all good. i was curious if anyone has had probs with these. they are 10.6 lbs for 15X7.
and orange!! haha
oh and the 2 valve is for "Dual valve stems facilitate the use of the less heat sensitive gas nitrogen for racing applications"
i couldnt find anyone in the RR/autoX forum running these.
and orange!! haha
hmm. ill try to find that thread.
https://honda-tech.com/zerothread?id=926966
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I have for sale a set of 4 (four) 15x7" Kosei TS 38mm offset and 4x100 lug pattern in silver. These are the lightest wheels Kosei makes as I know. Each wheel is 10.5lbs!
They only have two autocrosses on them (DC Tour in May). So they are almost brand new. They come with the center caps and special lugs that fit these wheels.
I am selling these because with my 205/50x15" Azenis they rub pretty bad. I'm sure a 205/50x15" in another tire would work better, since the Azenis are more like 215s.
just buy a set of ssr competitions...they are much lighter...As for the Azenis, I just put a set of 215/45/16 on my ssr's and the right rear is rubbin somethin fierce. I think I just need to do a little alignment magic on it though, cause right now that wheel looks to be cambered out farther than the left rear...oh well, we'll see
i beleive the SSR C's weight around 11.1 lbs. these are 10.6. now, i know the quality is most likely not up to par, but if i can get a set of these kosies for the price of about one and a half SSRs then im going with the koseis.
the kosei K1 TS???
around $170 or so. i thought they were as cheap as the K1's. but perhaps ill get lucky and find them that cheap
There's no ITR application in the 15 inch size. Check it out for yourselves...
http://www.koseijp.co.jp/engfl/n_p5_k1.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 »</TD></TR><TR><TD CLASS="quote">There's no ITR application in the 15 inch size. Check it out for yourselves...
http://www.koseijp.co.jp/engfl/n_p5_k1.htm</TD></TR></TABLE>
See, that is what I thought. Tirerack doesn not list an application for the ITR either...
