Installing a stereo in an 01 civic RIGHT NOW.. need help
Old Apr 3, 2005 | 12:56 PM
D50boy's Avatar
Default Installing a stereo in an 01 civic RIGHT NOW.. need help
Like it says, Im doing a stereo in an 01 civic...... I've done a lot of 96-00s...... but never an 01. Where should I start in order to get to the center bezel?
Old Apr 3, 2005 | 01:04 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Installing a stereo in an 01 civic RIGHT NOW.. need help (D50boy)
Found on google:
"01 civic is easy. You pop off the panel that the cigarette lighter is in, and then use a socket and remove the two 8mm screws. Then put your hands on the back of the bracket the readio is attached to and push the radio and the whole panel out of the dash. If you try to pry the radio assembly/panel out then you will leave marks on the dashboard.
If you buy a dashkit for the car, it should have instructions for removal, and reassembly."
Old Apr 3, 2005 | 01:23 PM
D50boy's Avatar
Default Re: Installing a stereo in an 01 civic RIGHT NOW.. need help (jlacoy82)
sweet.... and here I was takign the whole dash apart.. lol
Thanks man
JackRabbit
Nov 7, 2008 11:33 AM
lildrgn2.0
Audio / Security / Video
Nov 12, 2004 07:04 PM
Gdogg
May 17, 2003 09:22 PM
karter74
Aug 15, 2002 07:00 PM
