Installed DA master and brake booster..front brakes seize
I picked up a used master and brake booster from a DA and installed them in my crx yesterday. I drove it around a bit and the brakes felt awesome so I got on the highway and went to my friend's house. Once I exited I could smell my pads smoking so I took it slow to my friend's a couple blocks away. The pedal also felt very hard. I left it there overnight and towed it back.
I figured the pushrod in my booster had to be off so I took it out and it was slightly according to the manual. I adjusted it a little shorter than the specs and put everything back in. I jacked the front up and rev'd the engine a bit and sure enough the front brakes started gradually seizing up again.
I tried loosening the brake lines to the master and once I did that the calipers would release. The back brakes do not seize and the booster holds vacuum.
Anyone know whats going on? I figure I have to get a new master but want to be sure that will fix it.
I have stock brakes front and rear, and stainless lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">What type of brakes do you have on the front? are they integra 10.5 or civic STD/HF?
Stock crx dx.
And yes it was bench bled.
Stock crx dx.
I had the same problem after i installed my dc mc and booster. I changed my calipers cause i thought they were seize, cause i bough them off a DA at the junk yards. After bleeding it alot of times it was stilll the same but when I changed the brakes lines it went away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto »</TD></TR><TR><TD CLASS="quote">You mean the hard lines? </TD></TR></TABLE>
The rubber lines coming from the hard to the caliper. The problem with mines was that one caliper was always locked but right after I swap the lines it released.
EsCo_EsCo
Dec 21, 2007 05:57 PM
