I'm not a newbie i swear, haha
Old Apr 3, 2005 | 11:48 AM
WestEM1's Avatar
Default I'm not a newbie i swear, haha
Can someone technically and in detail explain to me about how the intake and throttle body works? ..i ask this because I have installed 64 mm bored TB and b18c5 IM with an AEM CAI...when I installed the bored TB....my CAI has been making sounds at idle. If anyone took the hollow AEM CAI tube and tapped it with their fingers like their playing a piano, it makes consecutive hollow echoing sounds, thats what i'm hearing from my CAI. My only best theory is that since the TB is bored 64 mm theres extra/excessive air hovering around inside the intake causing it to make the sounds I described. I checked their air filter and its on tight, intake on tight on the tb, hose and sensor on secure...so no air is leaking out. Thats my best theory because when i rev the car...it drops to 1.1 rpm then when it drops to normal 700-800 rpms it makes the sound as the needle descends. So it makes the sounds when it drops from 1.1-1.3 rpm -> 700-800 rpm AND when i'm at idle. Sorry for the long post
Old Apr 3, 2005 | 11:50 AM
jlacoy82's Avatar
71.192.16.183
Default Re: I'm not a newbie i swear, haha (WestEM1)
Is the butterfly a tight fit in the TB, or are there gaps around it?
Old Apr 3, 2005 | 11:53 AM
WestEM1's Avatar
Default Re: I'm not a newbie i swear, haha (jlacoy82)
I uninstalled the TB and inspected it, Butterfly is good and doesn't stick, i even wd-40 it to be safe, I checked the TPS sensor and it has right voltage and all the hoses of that TB is on tight...and the throttle cable isn't an issue cause i loosen it back to stock settings
Old Apr 3, 2005 | 01:19 PM
WestEM1's Avatar
anyone else have an idea?
Old Apr 3, 2005 | 02:35 PM
Above6K's Avatar
Maybe the sound your hearing is valve overlap? How does it run at the RPM's described?
Old Apr 3, 2005 | 02:55 PM
AbitAvenger's Avatar
maybe its just an intake noise
Old Apr 3, 2005 | 03:22 PM
B18C2_sedan's Avatar
Default Re: (AbitAvenger)
I agree with that. just noise
Old Apr 3, 2005 | 04:30 PM
WestEM1's Avatar
Default Re: (B18C2_sedan)
the sounds the intake is making is pretty noticeable...how come i never heard anyone have these sounds on their AEM CAI...car runs fine..the noise is just annoying...its intake noise yes..but not intake filter noise....its tube noise..
Old Apr 3, 2005 | 05:32 PM
WestEM1's Avatar
Default Re: (WestEM1)
hmm guess this thread is a lost cause..am i the only one who get these sounds from their AEM CAI?
mangogsr
Sep 1, 2012 07:44 PM
taimysho0
Sep 29, 2009 09:24 PM
teggsr925
Feb 8, 2006 04:07 AM
idriveanimport
Dec 13, 2003 04:20 PM
Zulu888
Sep 26, 2001 04:37 AM
