got some problems
Old Apr 3, 2005 | 10:51 AM
Mr_Si-R's Avatar
Default got some problems
for some odd reaseon my crx will only start sometimes...then others it will just crank. its really got me by the ***** cuz now i cant drive it. i checked the batt, the alternator, the the starter, ignition. now i dont know what else to check. i was told it might be a wire in the alternator or the fuel pump or the fuel filter. i dont know what else to look for. oh yeah EFMAN, thanks for the humble welcome...no joke. but could someone give me a list of **** to go over...i really dont know what else to look for.
Old Apr 3, 2005 | 10:54 AM
TEAM HATCH-N-IT 90's Avatar
Default Re: got some problems (Mr_Si-R)
check for a bad connection by the dizzy like coil,ETC
Old Apr 3, 2005 | 11:21 AM
Mr_Si-R's Avatar
dizzy?
Old Apr 3, 2005 | 11:26 AM
eda6's Avatar
Default Re: (Mr_Si-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Si-R &raquo;</TD></TR><TR><TD CLASS="quote">dizzy?</TD></TR></TABLE>
distributor
Old Apr 3, 2005 | 11:33 AM
Mr_Si-R's Avatar
word thanks, but i took off the "dizzy" cleaned it out tightend the little spinning thing and still no luck. as a matter of fact i just did that today. im running out of ideas man.
Old Apr 3, 2005 | 11:40 AM
mr. carpenter's Avatar
any codes? make sure the fuel pump is heard priming when you turn the car on.
Old Apr 3, 2005 | 11:55 AM
Mr_Si-R's Avatar
i think d15b7 block w/ 1.6 si non vtech head...it has an si intake manifold so it dont have a carb anymore. is that what you mean by prime the fuel pump?
Old Apr 3, 2005 | 12:18 PM
take it to a shop.
Old Apr 4, 2005 | 11:19 AM
Mr_Si-R's Avatar
the last option
Old Apr 4, 2005 | 06:09 PM
find some one to help you. no offense but you don't sound very informed on working on cars. this site is very helpful but you really need someone to help you out if you gotta do it yourself. it sounds like a distributor problem. you might need to replace it or it's internal components. what exactly does it do? just not run some times, or not start sometimes? check your ecu for codes.
_Spugen_
28
Dec 29, 2007 09:42 AM
93eg2james
Jan 23, 2007 08:58 AM
Spectrum24x
Jan 24, 2006 03:36 PM
Shift8Krpm
Dec 8, 2005 10:25 AM
Buckkaaaa!!
Jun 30, 2003 08:57 PM
