throttle body help
Old Apr 3, 2005 | 10:05 AM
Project_Civic's Avatar
Default throttle body help
i was wondering what size a stock throttle body was on a d16y7 and if i put a 70mm throttle body on what i would have to do to my intake to make it fit.
thanks
Old Apr 3, 2005 | 03:15 PM
civictildeath's Avatar
Default Re: throttle body help (Project_Civic)
http://www.knology.net/~jediklc/tbsize.htm
if you put a bigger throttle body on, you have to bore out the intake manifold to match the size of the throttle body. 70mm is a bit extreme. i would suggest the 62mm from the b18c5 (integra type R) and port match your intake manifold.
to make the intake match up, you will need some rubber connectors (assuming it is aftermarket intake like short ram or cold air)
called hose coupling
http://www.7453217467431.com/a...31612
what do you plan on doing?? is the TB just do get more air into the engine?? it doesnt add all that much power.
Old Apr 3, 2005 | 03:35 PM
Default Re: throttle body help (civictildeath)
i am planning on putting a SKUNK2 pro series intake manifold and throttle body-68mm so the intake manifold would match the throttle body.
you said the 70mm is a little extreme. would it be bad if i put a 68 or 70mm tb on?
Old Apr 3, 2005 | 04:19 PM
i didnt say it would be bad just extreme unless you are looking at 400 whp anytime soon.
as long as the intake manifold is prot matched with the throttle body you will be good
Old Apr 3, 2005 | 05:16 PM
jlacoy82's Avatar
71.192.16.183
https://honda-tech.com/zerothread?id=1199840
SSGojeta
Dec 27, 2008 09:29 AM
allnaturalb16
Sep 26, 2006 02:09 PM
turboZChatch
Jul 11, 2005 10:54 AM
Project_Civic
Apr 3, 2005 12:23 PM
bryant382
Sep 14, 2003 04:14 AM
