after market tachometer
Question, I would like to install a tachometer in my Honda civic. Is there a plug behind the dish already setup for the tach test, or DEC or ECU terminial. Or will I need to splice the wire going to the coil?
thanks
Surfdogs Kris
thanks
Surfdogs Kris
you were able to afford a 2005 civic? must have a high-paying job or your relatives/parents bought it for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">what year is the car you are putting it in.
there should be a tacho signal wire in the engine bay
the rest of the wiring should be pretty simple, power, ground, and illumination</TD></TR></TABLE>
