any Crower cam problem
Old Jan 27, 2002 | 06:02 PM
SCsol's Avatar
Default any Crower cam problem
hey there guys im putting 63402 cams in my ITR is there any problems i should know about with the valve hitting the pistions and what cam gear timing cam they handle +15 to-15 degrees please mail me back with some info and i did a search didnt find anything please help me out so i dont have to clay the pistions thanks again for all your help
and what kind of power did you guys get out of these cams please post dyno graphs
Old Jan 27, 2002 | 06:03 PM
SCsol's Avatar
Default Re: any Crower cam problem (lowsol)
and what valve springs do i have to use are new ITR springs ok
Old Jan 27, 2002 | 06:13 PM
non-VTEC's Avatar
i would go with the crower dual valve springs........they are very good and designed for those cams...........you dont need the ti-retainers but at least get the valve springs.....
if you ever have any problems with the cams later on in the future crower will put the blaim on the non-crower valve springs.
Old Jan 27, 2002 | 06:16 PM
eg6ajk's Avatar
i would worry i about putting crower cams in my car, there have been problems with the cams breaking, get some SKUNK2 or Toda, Jun or other good quality VTEC cams
Old Jan 28, 2002 | 02:20 AM
JDM_DOHC_SiR's Avatar
New User
Default Re: any Crower cam problem (eg6ajk)
good advice
Old Jan 28, 2002 | 04:38 AM
Mista Bone's Avatar
D Tranny Guru
Bad advice IMHO. If you are installing cams and NOT checking seat pressure, coil bind, and stem boss clearance, then keep a stock cam.
Can't slap on parts with out triple checking and expect everything to work forever.
BTW a Tuner SOHC will outrun a Parts Slapper DOHC everytime.
Old Jan 28, 2002 | 06:35 AM
SCsol's Avatar
Default Re: any Crower cam problem (Mista Bone)
ok mista bone help me out what is seat pressure, coil bind, and stem boos clearance thanks to everyone that posted
Old Jan 28, 2002 | 10:59 AM
eg6ajk's Avatar
mista: your right, but the thing is that the company sells these as just another bolt on part, they claim it will work with stock springs, retainers, people follow their specs..and it still happens
as a corporation they make a profit, with this proper R&D should be the outcome, and find out if it will work with a certain setups, all they have to do is just slap it on there, follow their instructions and see if it fails, if it does, why??? but they have not answered that question, they keep on blaming it on faulty installation, which seem not right, at least to me
I haven't heard of that many ITR/CTR cam installs failing or even Spoon or Toda Skunk2 at first had a problem, they admitted that the parts were improperly manufactured and they have changed and it hasn't happened.
Old Jan 28, 2002 | 11:04 AM
SCsol's Avatar
ok guys should i set the cams or are they not as bad as you guys make them out to be i need your input thanks
H22egguy
Engine Machining & Assembly
Oct 6, 2015 09:49 PM
Na-Spirit
Apr 19, 2010 02:24 PM
Home Wrecker
Aug 18, 2006 05:50 AM
PainfulTeg
Sep 23, 2002 12:08 AM
