help please
Old Apr 2, 2005 | 11:00 PM
camo_crx's Avatar
Default help please
heres the story
i had a b 16 wired to obd 1 in my crx. i recentlly went gsr boost. well when i dropped the b16 it ran good. well when i put the gsr in and finally finished the piping,and i run into another problem. when i go to crank the car it wont start. the main relay is making this fast clicking noise and so is the fuel pump. could it be a bad ground, my stock pump cant push my injectors, or something else. cars been down for two weeks now cause of problems with this swap. can someone help please?
Old Apr 3, 2005 | 07:54 AM
camo_crx's Avatar
somone has to have had this problem.
Old Apr 3, 2005 | 12:55 PM
camo_crx's Avatar
Old Apr 3, 2005 | 01:04 PM
Imsleeping's Avatar
Default Re: (camo_crx)
Fast clicking sounds like a dead battery or bad timing.
Old Apr 3, 2005 | 04:15 PM
RedRocketCRX's Avatar
Default Re: (Imsleeping)
if the relay is making a fast clicking sound then it probably took a dump on you. to find out if it is the relay when you put the ignition in the on position can you hear it make a whirling noise? if not then it did take a dump on you.
Old Apr 3, 2005 | 08:06 PM
camo_crx's Avatar
all i hear is the clicking from the relay and fell the fuel pump doing the same.
Old Apr 3, 2005 | 10:59 PM
NikoZai's Avatar
get a new battery before you post again
Old Apr 6, 2005 | 11:01 AM
its your relay not your battery. Your relay normally does a clicking noise, but it only does it one time when you put the ignition on the on position. If it has a constent clicking then it has to be your relay. plus if it was your battery your relay would not click.
Old Apr 6, 2005 | 01:33 PM
crxtreme89h's Avatar
Default Re: (RedRocketCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRocketCRX &raquo;</TD></TR><TR><TD CLASS="quote">its your relay not your battery. Your relay normally does a clicking noise, but it only does it one time when you put the ignition on the on position. If it has a constent clicking then it has to be your relay. plus if it was your battery your relay would not click.</TD></TR></TABLE>
Well, considering that your ignition sends the signal to the relay to make it click, turning on the fuel pump or whatever, it could also be his IGNITION STARTER SWITCH.
tech410
Apr 24, 2014 05:05 AM
woodwardba0526
Honda Civic (2001 - 2005)
Apr 18, 2012 08:22 PM
usdmhonda
Sep 12, 2011 02:48 AM
b1u3_5i
10
Oct 2, 2009 11:19 PM
camo_crx
Apr 3, 2005 02:23 PM
