del sol master cylinder in a crx Help!!
I question that I have is what do I have to do to put the del sol master cylinder in my crx? What brake lines do I need can I use the del sol line or gsr or accord? I have the gsr booster for master cylinder?
any help would be help so I can drive my baby soon.
I don't know anybody about del so but I put a ls/rs integra master cyclinder and brake booster and 40/40 valve with no mod. direct fit.
GSR might be a little difference do to Anti lock brake. not sure.
I am runing a gsr booster and a del sol master cylider with stock brakes because I can't afford to replace the master cylinder with a stock replacement.
And I had them lying around.
And I just want to know about the brake lines to the master cylinder and that is it.
I'll sell you mine. I got a extra one for 90 CRX hf.
for 20 shipped. I just did my upgrade.
as for the brake line. as long as the del so M/C is the same shape of the CRX one.
As far as GSR brake booster it will not fit. I think there are off set to a 90 degree angle.
i already have the booster in the car right now and all I am trying to find out what brake line to use the rear of the master cylinder the front one is the same the back one is bigger.
If bigger than your stock brake line hose. the you have to modifiy the brake line.
<U>http://www.hybridgarage.com/tech/brake2.html</U>
It might help you. I don't know how to do it.
Did the MC fit good with the GSR booster? or it sits at a angle?
accord91guy
Jun 20, 2010 06:11 PM
xerokill
Feb 24, 2008 09:23 PM
