How strong are stock axles??
Old Apr 2, 2005 | 03:07 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default How strong are stock axles??
I came home from the track last night and had a very good night, I went 14.7@92 but only had a 2.2 60ft. I have only a couple of mods and stock suspension. I am thinking of running some radials or maybe even slicks, I just want to know if I am at a good risk for snapping an axle, I don't wanna break an axle and pay the expensive tow home. Any good info will be greatly appreciated.
Old Apr 2, 2005 | 04:57 PM
Kyles ej1's Avatar
Default Re: How strong are stock axles?? (JDMThoughts)
you will most likely brake your axel launching on slicks
Old Apr 2, 2005 | 05:27 PM
hondaguyef's Avatar
Default Re: How strong are stock axles?? (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">you will most likely brake your axel launching on slicks</TD></TR></TABLE>
Not true. I used to launch my NA b16 @ 8k and only broke one axle on that setup (on 20x8 slicks). I was launching my low 12 sec. Turbo'd LS hatch @ 6K on OE axles and Never broke one. I now have a Turbo'd GSR in an EG and I have faith the OE axles will hold on the 24.5" slicks launching @ 6K +. I preload every launch
Phil
Old Apr 2, 2005 | 06:54 PM
boostedh22a's Avatar
Default Re: How strong are stock axles?? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
Just wondering how you a preloading the driveline in a street car??? Do you have a handbrake?? just curious
Old Apr 2, 2005 | 07:03 PM
FormulaGSR's Avatar
Default Re: How strong are stock axles?? (boostedh22a)
oe seems to be pretty strong. As soon as they get rebuilt by orielys, autozone ect they are pretty much done though.
OE
cheap Rebuilds
Old Apr 2, 2005 | 07:14 PM
Johnny O A20 KIller's Avatar
I use stock axles on 24.5 by 9 slick and they hold up.It depends on how you load the drive train and how much tire spin you get.I have gone 10.4 on them.I break them but I use Pep boys axles and I return them when they break.
Old Apr 2, 2005 | 10:13 PM
GIZZ - EXV's Avatar
Loved
my setup isnt a real powerhouse, ive been using my original oe swap axles since late '00. all kinds of variations on NA b20's in my 4dr and my hb street cars. probably a couple hundred trips down the track, never better than a 1.7 60 ft tho. run 20's and 22's, i dont preload, i just side step it and go. i just picked up some driveshaftshop stg 3's but will wait until these break first before replacing them.
Old Apr 2, 2005 | 10:32 PM
Default Re: How strong are stock axles?? (GIZZ - EXV)
So you are saying it would be safe to run slicks then but just to preload the tires. What do you mean preload? I have never heard that term before. I am not really new to racing, just new to that term. Thanks for the helpful input.
Old Apr 3, 2005 | 09:03 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">
Just wondering how you a preloading the driveline in a street car??? Do you have a handbrake?? just curious</TD></TR></TABLE>
I use the e-brake by holding in the button but, I have seen a few people delete the locking mechanism to make it easier.
Phil
Old Apr 3, 2005 | 03:13 PM
nsxmatt's Avatar
Default Re: How strong are stock axles?? (FormulaGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">oe seems to be pretty strong. As soon as they get rebuilt by orielys, autozone ect they are pretty much done though.
OE
cheap Rebuilds </TD></TR></TABLE>
I've run over 2 years and 50k miles on the same set of cheap reman axles without one problem. Lots of 1.6 60ft's on slicks. The key is preloading like was said before.
It's like hitting a nail with a hammer. You lay the hammer against the nail and press it isn't going anywhere. Swing it and give it about 2 feet to build up momentum and it's gonna do some damage. The key is taking the intial load off the drivetrain but putting some pressure on the clutch. I have the clutch released a little right before I launch and release it slower. That will heat up the clutch but if done right it will last a while and keep stress off the whole drivetrain including the tranny/diff.
Old Apr 3, 2005 | 06:04 PM
turboEGhatch's Avatar
Default Re: How strong are stock axles?? (nsxmatt)
Autozone remans + 26x9.5 mickey thompsons + 450+ WHP here
Old Apr 3, 2005 | 08:01 PM
John221's Avatar
Default Re: How strong are stock axles?? (turboEGhatch)
stock axles are good for me so far. I usually launch 6,500 rpms with 22x8x13s
you should be fine.
Old Apr 3, 2005 | 08:07 PM
Hondog's Avatar
Default Re: How strong are stock axles?? (defiantEG)
Same here stock Honda axles in my K20 swap, I run 24.5-9-13 slicks I've run 1.58 60ft's even launched in 2nd when I had a gbox issue and ran a 1.8 60ft launching from 9000rpm..
Honda axles
Old Apr 3, 2005 | 08:13 PM
allmotorb20vtec's Avatar
Default Re: How strong are stock axles?? (Hondog)
stock gsr axles full race season street car 1.600 60-fts all day still intact.
Old Apr 3, 2005 | 08:27 PM
Suprdave's Avatar
I ran stock axles last season...launching at 7800 off a 2-step.
23x8x13 MH Slick....1.61-1.64 Average 60ft. 7psi in tires...
Old Apr 3, 2005 | 11:22 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondog &raquo;</TD></TR><TR><TD CLASS="quote"> I've run 1.58 60ft's
WOW!!! I bet that feels nice. Best 60' I have ever had was w/ my NA B16 and it was a 1.79 . Sorry it's off topic.
Phil
Old Apr 4, 2005 | 12:23 AM
SHystrdyGSRtdy's Avatar
good to know stock axles will hold up... now to just practice the preloading
Old Apr 4, 2005 | 06:36 AM
Antilag's Avatar
Default Re: How strong are stock axles?? (SHystrdyGSRtdy)
i use a line lock to preload, my trigger is on my shifter, slowly release the clutch as soon as its a go i release the button, i have a good launch with everything preloaded. no axle breaks yet.
Old Apr 4, 2005 | 07:01 AM
underpressure02's Avatar
John if your worried about breaking axles get a set from autozone then if you break it we can change it out at the track. And they have a life time warrenty so you can just take the broken one back. It only takes a few mins not that hard.
As far as preloading I will show you this weekend how to do it.
I was on stock axles for a while with my 24.5 slicks and my bfg. I never had a problem and I was not preloading my drivetrain at first.
Old Apr 4, 2005 | 10:17 AM
civic97dx's Avatar
Default Re: How strong are stock axles?? (underpressure02)
OK, Back to this preloading thing, what exactly is it? Do you ease off the clutch a little and not side-step the clutch as bad? sorry to chime in but I'd like more info, I'm buying slicks and need to learn more about them.
thanks
Old Apr 4, 2005 | 10:23 AM
turbo*s2k's Avatar
Default Re: How strong are stock axles?? (civic97dx)
I haven't had a problem running stock axles. 24.5x8.5-13 slicks / 400+hp.
Old Apr 4, 2005 | 11:09 AM
redzcstandardhatch's Avatar
something different
i make 155wtq, and i've never broken an axle (still on 200,000+ mile civic standard axles)
my buddy make 132wtq and has broken several autozone remans.
i guess its up to how you drive, and how good the axles are. some autozone remans SUCK. some have treated us fine.
Old Apr 4, 2005 | 03:40 PM
Default Re: How strong are stock axles?? (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">John if your worried about breaking axles get a set from autozone then if you break it we can change it out at the track. And they have a life time warrenty so you can just take the broken one back. It only takes a few mins not that hard.
I was on stock axles for a while with my 24.5 slicks and my bfg. I never had a problem and I was not preloading my drivetrain at first. </TD></TR></TABLE>
Yea Chad, your gonna have to show me how to do it. I was all excited I got a 2.2 on my virtually stock GSR. I am gonna get radials really soon.
Thanks to all you drag guys giving me good info, I am gonna look into preloading the clutch. I will just have to practice it some more. Thanks again. If anyone else has any suggestions please let me know.
Old Apr 4, 2005 | 06:50 PM
also remember wheel hop breaks axles I think worse then dr or slicks. You might want to look into getting some traction bars.
Old Apr 5, 2005 | 01:09 PM
I am looking into getting a set of Full-Race traction bars, or L-con ones. Unless you feel really confident in your welding skills and wanna make me a set Chad.
Hondakorn
Honda Civic (2001 - 2005)
Sep 24, 2009 06:07 PM
Boostedb20EH2
Feb 25, 2008 04:55 AM
the.hamburglar
Aug 5, 2007 08:06 AM
DLB1994
Feb 18, 2002 09:59 AM
