cam question?
i am currently running a b16 81.5 bore eagle h beam rods and 12.5 JE pistons ... i was planning on a little spray in the future is the reason i went with the heavy rods .. ok a lot! ... my question is with out claying my head which i dont want to do cause the engine is assembled now and in my daily driver with stock cams and valve train ... what cams would you suggest for my set up and not have to worry about piston-valvle cotastrophe .. i was looking at the blox and buddy club cams but i am scared to take that step from "stage III" to the IV ... any knowledgable input would be greatly appreciated ... ps i am running a stock head gasket! and stock deck height and not milling on the head ... i am aslo looking into the BLOX cams any one have any exp with the Blox cams ..? thanks in advance and sorry for the repost but i put it in the wrong section previously... i am also looking for a good sit that has an illustration on the vtec engagement process for the claying ... thanks ...
b16bri
Oct 15, 2010 05:51 PM
Used2beAb16
May 4, 2004 04:29 PM
