stock block b16a2, suggested cams?
Old Apr 2, 2005 | 02:22 PM
Terrible One's Avatar
Default stock block b16a2, suggested cams?
which cam upgrade would be best for a stock block b16a2 w/ comptech ice box, aebs im, jdm 4-1, 2.5" exhaust. i think that the following cams would do well with the 10.2:1 cr but which one you guys think would be better for daily driven power.
USDM Integra Type-R
Blox Type A
Buddy Club Spec 3+
Skunk2 Stage 1
Rocket Motorsports M21
the cams will also be used in conjunction with rocket motorsports gen1 valve springs/retainers and tuned by hondata
Modified by ORiG1NaLKhMeRsTA at 7:03 PM 4/2/2005
Modified by ORiG1NaLKhMeRsTA at 7:04 PM 4/2/2005
Modified by ORiG1NaLKhMeRsTA at 7:05 PM 4/2/2005
Old Apr 2, 2005 | 02:50 PM
Default Re: stock block b16a2, suggested cams? (ORiG1NaLKhMeRsTA)
what do you guys think?
Old Apr 2, 2005 | 05:08 PM
cmon guys, just need some suggestions or advice. i've heard the buddy club 3's are really good stock compression street cam.
Old Apr 2, 2005 | 05:23 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
the itr or ctr cams since your motor is bone *** stockplus your going to need other stuff if u want to take full potential of any cams. like header exhaust intake
Old Apr 2, 2005 | 05:24 PM
Default Re: stock block b16a2, suggested cams? (street dreams)
my bad i guess i should of read your post a little better. forget about the header and stuff
Old Apr 7, 2005 | 09:35 PM
TrackSpeedRacing's Avatar
Default Re: stock block b16a2, suggested cams? (The Terrible One)
Blox Racing tuner series type-a is what we suggest for your stock block b16a2. Get them now for $535.00 w/free ups ground shipping. http://www.trackspeedracing.com Thanks
Old Apr 8, 2005 | 10:09 AM
92Jspec's Avatar
Default Re: stock block b16a2, suggested cams? (1320JDMGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320JDMGSR &raquo;</TD></TR><TR><TD CLASS="quote">Blox Racing tuner series type-a is what we suggest for your stock block b16a2. Get them now for $535.00 w/free ups ground shipping. http://www.trackspeedracing.com Thanks</TD></TR></TABLE>
Old Apr 8, 2005 | 10:47 AM
evilricer's Avatar
Default Re: stock block b16a2, suggested cams? (92Jspec)
the bc spec 3+ are some sick cams and give good power.
Old Apr 8, 2005 | 01:04 PM
D-Rob's Avatar
Default Re: stock block b16a2, suggested cams? (evilricer)
I kinda' like my Skunk2 Stage 1's.
Although to see some real good gains with these cams, you need a method of raising the rev limiter.
The Skunk2 Stage 1's are pretty much a CTR cam with a good bit more top end.
Old Apr 8, 2005 | 01:54 PM
Rocket's Avatar
Default Re: stock block b16a2, suggested cams? (drobinson)
CTR Intake cam for near stock B16.
Spend the rest of your money on SMSP header.
Old Apr 8, 2005 | 04:18 PM
thevanitygroup's Avatar
Default Re: stock block b16a2, suggested cams? (Rocket)
CTR cams, cam gears, AFPR, FP gauge and VAFC. That will atleast make you tunable and for cheap, I think its always best to start there.
Old Apr 12, 2005 | 12:31 PM
EK2.0's Avatar
bump
Old Apr 12, 2005 | 12:38 PM
vart's Avatar
Default Re: (JDMLVR)
prolly some CTR cams, or skunk2 stage 1, or even the 2's depending on what your goals are.
Old Apr 12, 2005 | 07:46 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: stock block b16a2, suggested cams? (Terrible One)
I heard the skunk2 cams r good for the b16 set up, but let us know how it goes either way... ill be shoppin for cams soon also
Old Apr 12, 2005 | 09:41 PM
Kendall's Avatar
With the stock compression, CTR's should do the trick nicely. Consider bumping up the compression via a thin headgasket and/or high compression valves before seriously considering any of the other listed options.
Old Apr 12, 2005 | 09:43 PM
it looks like the ctr cam(s) is what everyone is choosing.
Old Apr 12, 2005 | 10:32 PM
UncleD's Avatar
Default Re: (Terrible One)
The Rm M21's are a turbo cam, so I wouldn't do those. The nice thing about the ctr is for 1, you have the reliability...they are going to idle and act as if the motor is stock and will give you good gas mileage. For 2, they won't wear out. You can buy a set of used type r cams and have the confidence that they aren't flat or have wear. 3, you can always re-sell them for what you paid for them. Since they are a OEM camshaft, people know that they are still "good" and that they aren't abused or whatever. 4, you don't need to change your factory valvetrain. Assuming you keep your stock rev-limiter, you can run these cams right now...plug and play! Both of my roomates have installed type r cams in there stock B16's and it HONESTLY made a huge difference. People assume that they are weak because they are o.e., but Honda knows what they are doing..........they get down!
Old Apr 12, 2005 | 11:34 PM
madtownhonda's Avatar
Skunk2 Stage 1 in this b16a2 for the last 45K and they were used when I bought them for $400. I still get 34mpg. Stock valvetrain.
Old Apr 12, 2005 | 11:48 PM
ef92b's Avatar
Default Re: (madtownhonda)
hi everyone. i don't mean to jack up your thread but what if i have a ported head, ommi power valve train(springs, valvles, ti retainers) and with CTR pistons(0.25 OS) in a B16A2, will BC III+ better than the CTR ones.
also IHE upgrade is there plus a lightened flywheel.
mayn thanks
Old Apr 13, 2005 | 06:23 AM
rocket said just to upgrade the intake cam. would this be enough or would you guys recommend both intake and exhaust cam? is the ctr exhaust cam almost the same as the b16a2 cam?
Old Apr 13, 2005 | 06:42 AM
JIDUM_Undercover's Avatar
im a big fan of BC spec 3's. Nothing but good things!
Old Apr 13, 2005 | 07:14 AM
UncleD's Avatar
Default Re: (JIDUM_Undercover)
CTR exhaust cam - 235 duration, 10.5 lift
B16 exhaust - 216, 9.63
teamjdm239
Dec 13, 2009 05:07 PM
Benefitx
Feb 20, 2009 04:13 PM
Joey B 18C
Aug 3, 2004 11:19 AM
deftones0817
Jul 15, 2004 05:48 PM
THCk20eg
May 4, 2004 04:18 PM
