got wingswest avenger kit for civic.....how to install?
Old Jan 27, 2002 | 04:45 PM
hobo79's Avatar
New User
Default got wingswest avenger kit for civic.....how to install?
where is a site for a step by step for installing a ww avenger body kit?
what kind of tools do i need? THANKS!
Old Jan 29, 2002 | 11:56 PM
hobo79's Avatar
New User
Default Re: got wingswest avenger kit for civic.....how to install? (hobo79)
i think all i need is a screwdriver, and 10-12mm socket and that should work out fine right? bodykit already has the drilled holes. and then i figure i jack the car up with 2 jacks. is that about right?
Old Jan 30, 2002 | 09:43 AM
shamoo's Avatar
Will you make something up for me please?
You pretty much got it. Assuming all you want to do is mount it, that's all you need. 10-12mm sockets, and a philips head for those "clip-in screws."
Just be careful though, like 50% of kits don't fit perfectly the first time. You might even have to trim some parts and bond some areas. Just to let you know. Good luck.
EDIT: Whoops....all you really need is one good hydraulic jack, and two jack stands. Do one side at a time. Do the front.....then the rear....then the sides. You don't really need to jack up anything for the sides. Good luck.
[Modified by shamoo, 1:44 PM 1/30/2002]
Lastgsr
Audio / Security / Video
Apr 20, 2004 07:39 PM
smslude
Apr 27, 2003 01:48 AM
Neospite
16
May 25, 2002 09:04 AM
hobo79
Feb 4, 2002 05:29 AM
CivicAlpha
Jun 5, 2001 07:10 AM
