Hondata and Peak and Hold injectors
Old Apr 2, 2005 | 01:14 PM
wappid's Avatar
Default Hondata and Peak and Hold injectors
I have a Hondata Stage 4B and I can get some cheap peak and hold 440cc injectors. I have been told 2 different stories about resistor boxes? I have a 95 Integra SiR-G which runs saturated injectors, people say that with my hondata i do not need a resistor box as the ecu can use either, where as other people say that i still need a resistor box?
any help would be appreciated
Old Apr 2, 2005 | 03:01 PM
kevino002's Avatar
Default Re: Hondata and Peak and Hold injectors (wappid)
bump for info.
Old Apr 2, 2005 | 03:42 PM
ochsy03's Avatar
Default Re: Hondata and Peak and Hold injectors (kevino002)
i would say yes u need a resister box but not 100% sure
Old Apr 2, 2005 | 03:59 PM
Nonsteezy's Avatar
hondata does not have resistors built in so u will have to run a resistor box in order to run the peak and hold injectors, if u search on the site there are rwrite ups on how to do that
Old Apr 2, 2005 | 06:57 PM
red_crx's Avatar
yes you will need a resistor box to use the peak and hold injectors. you should be able to find one at the junkyard from any obd0 car
Old Apr 2, 2005 | 07:10 PM
BoOsTiN Dc2's Avatar
Default Re: (red_crx)
yup you need a resistor box from obd0 car like crx and stuff. Im running 1200cc injector peak and hold and i run a resistor box
Old Apr 2, 2005 | 08:53 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_crx &raquo;</TD></TR><TR><TD CLASS="quote">yes you will need a resistor box to use the peak and hold injectors. you should be able to find one at the junkyard from any obd0 car</TD></TR></TABLE>Or...90-97 Accords. Not too sure bout the 98-current Accords though.
Civic92Turbo
Aug 9, 2007 03:09 PM
teg racer 877
Feb 12, 2006 11:44 AM
spooned out
Aug 14, 2005 09:18 PM
Sprockets
Dec 21, 2002 12:56 PM
93LSivic
Mar 25, 2002 08:35 AM
