Help Koni Install Question
Old Apr 2, 2005 | 10:07 AM
danelot's Avatar
Default Help Koni Install Question
I'm in the middle of an install on my ITR. I have one of the front struts reassembled. I'm trying to torque the pair of nuts that hold the entire assemebly together. The shaft of the shock keeps rotating and I cannot tighten to spec. The stock shock use an allen key to prevent this. How do keep the shaft from rotating?
Thanks
Old Apr 2, 2005 | 10:13 AM
.RJ's Avatar
.RJ
Default Re: Help Koni Install Question (danelot)
https://honda-tech.com/zerothread?id=891136
Old Apr 2, 2005 | 10:47 AM
danelot's Avatar
Default Re: Help Koni Install Question (.RJ)
I've read your thread and it's been a big help, but it doesn't address my issue. With the spring compressed, I ran the nuts down the shaft. When I try torquing them to spec, the shaft moves. How do I keep this from happening?
Old Apr 2, 2005 | 12:31 PM
.RJ's Avatar
.RJ
Do the final torque with the car off jackstands Make sure you use 2 nuts *per shock*
Old Apr 2, 2005 | 01:34 PM
stumpyf4's Avatar
You should see a 7mm (i think) hex at the top of the shaft just under the adjustment tab. Slip in a 7mm open ended wrench and you're good to go.
beanbag
Suspension & Brakes
Apr 14, 2008 01:43 AM
datssoled
Suspension & Brakes
Sep 5, 2007 10:49 AM
Jordans95si
Feb 12, 2006 01:28 PM
mmmVTEC
Jul 8, 2004 12:12 PM
AndyD
May 9, 2004 02:16 PM
