hood wont shut all the way?
ok need alittle help guys, my hood will not shut all the way. it locks but is still sticking up alittle. I'm ganna need a new cable for the hood latch and a cross member? i think thats what its called. (bar that goes between the headlights that the hood latches down to)
does anyone know where I can order these two things? other then honda.
thanks...
thanks...
you can also screw down the latch on your hood, if you look at the hood there is the spring with a bolt threw it just loosen the bolt at the top and then screw it in with a screw driver... pm me if that doesn't make sence to you
andlude
Jul 9, 2008 10:06 AM
GetCaughtDead
Oct 25, 2004 05:24 PM
