wanna bore the b18c instead of the b20!! need advice!!
Old Jan 27, 2002 | 04:03 PM
PrettyRicky's Avatar
Default wanna bore the b18c instead of the b20!! need advice!!
i already did a search!!!!!!!
hey guys...well my plan on doin the b20 is dead...i was strongly advised on jut boring out my b18c to 84.5mm and resleeving...just wondering if anybody hase done this kinda work and could please help me out with some misc info that i might need to know...also how much does this kinda work cost???? this is gonna be my daily driver..lol....
i figured that boring out the b18 would be more reliable than the b20...with this setup does anybody know if i can rev high maybe to 9500 rpm or what??? also i thought it would be better expecially i have oil squiters andthe crank gridle over the b20.....
if i did bore i would of course get eagle rods and some high comp pistons from either JE or endyn with some new rings....
is there any thing that i might ned to know???????
Old Jan 27, 2002 | 04:28 PM
Eeepers's Avatar
New User
Default Re: wanna bore the b18c instead of the b20!! need advice!! (PrettyRicky)
You should consider adding deck height to get a better rod ratio if you're going to 9500 rpms.
Old Jan 27, 2002 | 04:31 PM
Reid's Avatar
Global Moderator
You would need to resleeve the block to bore it out to 84.5mm. Look to spend at most 1000 for resleeving.
Old Jan 27, 2002 | 04:44 PM
Project SSAP1's Avatar
Default Re: wanna bore the b18c instead of the b20!! need advice!! (Reid)
hey my first post.....I got a price to for golden eagle sleeves for 750 from import builders.....how much to bore out to 84.5mm??? also anybody know the cost of darton sleeves???? and whats the difference between those sleeves compared to golden eagle sleeves???? is the deck height needed???
Old Jan 27, 2002 | 04:49 PM
primoEF's Avatar
This is what we did to a B18C GSR motor:
- resleev and bore to 84mm
- use a 90 Prelude 2.0L crank
- Eagle LS rod
- JE pistons
one problem is that when the crank is in, ipoo pooing the oil jets, have to grand off a bit of the bolts for the oil jets, I think the motor is close to 2.1L
Old Jan 27, 2002 | 05:14 PM
Default Re: wanna bore the b18c instead of the b20!! need advice!! (b18k1)
is that somebodys daily driver???...please explain the problem with using the prelude crank??? im kinda slow..lol..is the 90 prelude crank a good choice to use with the a 5gen teggy b18c??? y not just use the 18c crank????
Old Jan 28, 2002 | 04:10 AM
primoEF's Avatar
Default Re: wanna bore the b18c instead of the b20!! need advice!! (B18cKiller)
This is like a project car that we wanted to make it into a 2.0L and the guy doesn't want to use a B20 block, and seems the only crank will fit is a 90 Prelude 2.0 crank, and it did work out fine
Old Jan 28, 2002 | 09:06 AM
Tomakit's Avatar
No such thing as a 5th gen integra.
To get a 2.0L b18c you are gonna hafta re-sleeve, and bore over to 84.5mm. You also need an 85mm cometic headgasket, or you need to open up the stock gasket. Further, you are also going to want to get the head deshrouded to match the 84.5mm bore of the block. This alone will give you a worse r/s ratio than a normal b18c, so revving to 9500 on a daily basis probably isn't the best idea, even with upgraded rods, pistons. (To rev that high you are gonna need to spend lots of $$ making the head strong enough to handle those revs).
There are a few guys on this board who have done this already, you might wanna IM them.
Tom
Old Jan 28, 2002 | 09:26 AM
Lip's Avatar
Lip
Default Re: wanna bore the b18c instead of the b20!! need advice!! (Tomakit)
Tom
or use the CRV gasket and reroute your oil feed like i did.
https://honda-tech.com/zerothread?id=102818
Old Jan 28, 2002 | 09:46 AM
JimmieD's Avatar
jsut boring out isnt going to affect your rod/stroke ratio if that is what you are saying. or are you talking about the prelude crank???? i am confused.
Old Jan 28, 2002 | 10:29 PM
my bad..didnt pay att to what i was writing...lol...hey LIP damn nice job on that toda integra...damn..what kinda job do u have to spend all that doe on the teg???? and can u put me on..lol..
[Modified by B18cKiller, 7:30 AM 1/29/2002]
Old Jan 28, 2002 | 11:40 PM
threatcon13's Avatar
New User
Tom
what happens if you dont deshroud the head?
Old Jan 29, 2002 | 10:36 AM
houston's Avatar
Default Re: wanna bore the b18c instead of the b20!! need advice!! (turbo01gsr)
you loose effeciency or you get piston slap depending on what pistons you run..
deshrouding is more of a valve thing.. what you need to do to the head is SPOT FACE.
I personally think the GE sleeved B18c block with all b18c components (crank)
is much more reliable than b20 or b18a/b w/sleeves
prelude and LS cranks blow goats.
Old Jan 29, 2002 | 03:59 PM
Default Re: wanna bore the b18c instead of the b20!! need advice!! (houston)
i think the best bet would b 2 stick with the b18c and just bore it to 84mm and if possible use an oring with all other b18c parts!! more reliable and can rev that biatch all day!!
Old Jan 30, 2002 | 04:42 AM
Lip's Avatar
Lip
i'm just very consistant....thats how i afford it. that and alot of buying and selling
dannyneedshelp
Oct 15, 2008 09:22 PM
xQB21x
17
Oct 15, 2008 12:29 PM
pleej
10
Jul 7, 2008 01:15 AM
COUPE-B20
Oct 16, 2004 02:51 PM
swaplighter
Jan 26, 2004 07:08 PM
