Is it possible to tig mild steel to 4140?
Old Apr 2, 2005 | 07:57 AM
essex's Avatar
Default Is it possible to tig mild steel to 4140?
I need to weld a mild steel bracket to some 1" solid 4140 rod...will this be a problem...if not what filler do I use.
Thanks
Old Apr 2, 2005 | 06:09 PM
essex's Avatar
Default Re: Is it possible to tig mild steel to 4140? (essex)
up
Old Apr 2, 2005 | 07:04 PM
Engloid's Avatar
OG Fabricator
Yes, it can be done. Use whatever filler you usually use on the 4140.
Old Apr 2, 2005 | 07:20 PM
Goullish's Avatar
Default Re: Is it possible to tig mild steel to 4140? (Engloid)
Oxweld 32 works nicely.
RJ#9
Welding / Fabrication
Jan 19, 2009 06:18 PM
idriveadelsol7
Apr 16, 2005 01:16 PM
00b18b
Oct 5, 2001 05:13 PM
